Old 05-13-2015, 09:49 PM   #1
Wizard62
Wizard62's Avatar
Gears
I have a 1971 C30 Cheyenne CST Longhorne Camper Special with a 402 and Turbo 400. It has 4:10 gears in the rear with a limited slip diff. I want to change the ratio to a more highway friendly setup since it will not be used for towing in the future. As long as I'm alive. LOL. Where would I look for a suitable new set of gears and what would be a good ratio to look at? I'm open to all advise. Thanks. Glen.
Wizard62 is offline   Reply With Quote
Old 05-13-2015, 10:30 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Gears
Hi Glen and welcome to the greatest site on the net. We love pictures here and would like to see some of your C30 Longhorn. I cant help you with your gear question but I'm sure in short order you will get an answer.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-13-2015, 11:16 PM   #3
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: Gears
Welcome to the board!
The C30 has full floating rear axles and I don't know the available gear ratios for those, but if it helps, A more friendly gear ration would be 3.73 then 3.40 then even more friendly 3.08. There should be options close to those for your HD rear axle.
Most of the C10's you see on the street have a 3.08
Good luck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 05-13-2015, 11:44 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Gears
Welcome to the board! Do you know what type of diff the truck has? Just asking because it's a C30, so it might be an Eaton. If so, 4.10 is the best you'll find, unfortunately.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-13-2015, 11:53 PM   #5
wbc409
Re: Gears
You could upgrade to a rear axle out of a newer truck or install a gear vendors overdrive unit. The add on overdrive is a bit expensive b UT virtually bullet proof.
wbc409 is offline   Reply With Quote
Old 05-14-2015, 05:42 AM   #6
SS Tim
SS Tim's Avatar
Re: Gears
With the factory Chevy/Eaton H072 rear axle, 4.10s were the highest ratio offered. Running a tall tire helps but the fact is it is a 5000lb truck designed to move a load. 33-31" tires are going to give you 2700-2900rpm at 65.
As pointed out above an axle change to a later 14 bolt will give you some higher choices thus cutting engine speed in all gears with about the same axle rating.
If you won't be carrying much in back you could downgrade (with stock parts) to the 3.54 Dana 60 axle used in some C20s. 33-31" tires are going to give you 2350-2500rpm at 65.
The O/D option is probably the best choice giving you and extra top gear and being able to plit the lowers, at a cost.
http://www.summitracing.com/expertad...tio-calculator
SS Tim is offline   Reply With Quote
Old 05-14-2015, 12:34 PM   #7
hugger6933
Re: Gears
My one ton has 6:17 gears???!!! No wonder it is a low mile truck with the 400 small block someone put in it probably gets the best of about 4 mpg. No a cruiser for sure. Jim
hugger6933 is offline   Reply With Quote
Old 05-14-2015, 12:43 PM   #8
SS Tim
SS Tim's Avatar
Re: Gears
Is it a ten lug wheel pattern?
If so it has the H0110 11K axle.
Old 05-14-2015, 12:53 PM   #9
Wizard62
Wizard62's Avatar
Old 05-14-2015, 12:55 PM   #10
Wizard62
Wizard62's Avatar
How do I find out what type it is? I have the original build sheet. Thank you.
Old 05-14-2015, 01:24 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Gears
Pic of an Eaton. Notice the pinion preload (deflection) bolt on the left side of the case. There are basically two types, HO52 on 3/4 tons and HO72 on one-tons. The center sections are virtually identical and the primary differences are brakes. Also, some HO52s have the load bolt and some do not -- all HO72s have it.
- Mike -
RIP El Jay
Old 05-14-2015, 01:30 PM   #12
SS Tim
SS Tim's Avatar
Re: Gears
Here is a 71 C30 Longhorn H072 rear as installed from the factory.
Old 05-14-2015, 02:25 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Gears
A lot of people mistake the Eaton for a "10 bolt" since there are only 10 bolts holding the diff cover on.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-14-2015, 02:45 PM   #14
davepl
davepl's Avatar
Re: Gears
If it were me, and it recently was, I actually went to deeper gears (4.56) and an overdrive (0.67) 200-4R trans. That gives me an effective final drive of 3.05. With out tall truck tires that's probably like 2.73s in a car.
It may well be cheaper to swap the trans than to change the gears. I have $3K into my rear axle (Dana 60) to rebuild it, change the gears, and add posi.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-14-2015, 08:06 PM   #15
Wizard62
Wizard62's Avatar
Re: Gears
I would love to post more pictures but I can't find out how to do it. Thanks
Old 05-14-2015, 09:25 PM   #16
kwmech
Re: Gears
My Longhorn had a dana 60 in it with 3.54s and a 396.
Old 05-14-2015, 09:32 PM   #17
hugger6933
Re: Gears
The way I read my GVW tag I thought it said 11000 pounds. But it does have the 8 lug pattern am I missing something? Would a vin number do better in helping me figure out what is in the rear of my truck? Don't mean to thread jack but that rear gear chart has me thinking about a truck I haven't driven more than a couple hundred yards. Probably won't drive it much more than that if it is that low geared. jim
Old 05-14-2015, 10:25 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Gears
^^ Best way to know for sure, open it up and count the teeth. Next best method, jack it up and count the driveshaft revolutions to rotate the tire one time.
- Mike -
RIP El Jay
Old 05-15-2015, 07:06 AM   #19
Re: Gears
If your truck is original there is absolutely no doubt it has an HO72. No Dana 60 available in a 1t. I have that ratio in my '72 and I'm just fine with it. How fast do you need to go?
Your only choice to go taller gears is a later axle swap. Most modify the 14-bolt
Old 05-15-2015, 09:28 AM   #20
67 chevelle
67 chevelle's Avatar
Re: Gears
Great advise , they are plentiful and bulletproof , Id look for 342 gears as long as you are not running tall tires
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-15-2015, 10:55 AM   #21
57taskforce
All about them K’s
57taskforce's Avatar
Re: Gears
I'll further tims advice on the 14 bolt by saying if you can find one that has stamped steel spring perches, they are easier to get off than the cast steel perches. Modifying it s easy if you can weld.
Tyler
57taskforce is offline   Reply With Quote
