![]() Join Date: Sep 2006
transmission line question
wondering what fitting i need to put into the transmission to go to an fittings not sure what the thread going into transmission is.
#2 | |
meowMEOWmeowMEOW
Re: transmission line question
Mind telling us what your trying to hook to what? If you want to run AN fittings, the 60e and 80e use different types. The trans cooler side of things will require whatever AN size converts. I.e. -6 is 3/8" line. The 80e also has a specialized fitting with a straight cut AN and an extension tube. This special fitting isn't needed if your adapting from the hardline, but will be needed to directly replace the case-side fitting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I forgot to put that I am running -6 an lines getting everything together for the ls swap
![]() Join Date: Mar 2004
Yea, but what transmission ?????
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
crap 4l60e its late not thinking
