Old 05-14-2015, 01:42 AM   #1
hilandr452
hilandr452's Avatar
BBC head gasket problem
Hey guys,
I am rebuilding the 454 in my 71. here's the problem, when I was getting ready to install the heads, there was a warning note in my fel pro gasket kit. It says there are 2 series of coolant configurations for the mark IV 454's. One uses the coolant holes in the bottom of the head and the other does not.
The heads I am using are from the original 402 because they are oval port and the original heads were the small square port. 454 is from an 83 GMC 1 ton.
The 402 does not have the lower coolant holes in the block, but it's heads do. The 454 has the lower coolant holes in block and head.
Which gasket do i use?
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 05-14-2015, 07:30 PM   #2
hilandr452
hilandr452's Avatar
Re: BBC head gasket problem
No one knows?
Dan Smith
Old 05-14-2015, 11:20 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Fel Pro 1047 will work. Work on all series of BBC block & head configurations. I used it on my '78 454 with Edelbrock heads.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
