05-14-2015, 08:48 AM | #1 |
Is the caddy 425 a boat anchor?
Or can i hop it up to 500hp and 500tq? i want to drop it in a 79 blazer
05-14-2015, 08:54 AM | #2 |
Re: Is the caddy 425 a boat anchor?
Boat anchor.
05-14-2015, 09:48 AM | #3 |
In stock form it might be a boat anchor but if you have the time and resources and some extra money, you can make it happen.
Check out all these threads. https://www.google.ca/webhp?sourceid...dillac%20motor |
05-14-2015, 09:57 AM | #4 |
Wouldn't it be cheaper to build a 454 up to that power?
05-14-2015, 09:59 AM | #5 |
05-14-2015, 10:06 AM | #6 |
Depends how different you want to be,You can go cummins swap or a turbo v6 or turbo small block.
05-14-2015, 04:10 PM | #7 |
Cruzzzn' Vet
Stick with the 500 caddy
05-14-2015, 04:19 PM | #8 |
The 472/500 Caddys are a better choice. Not sure how much cubic money it would cost to build one to 500hp. But 500 lb/ft torque is easy. Especially with the 500. Best bet is to locate a 70 engine. They were Eldorado only at that point, which is good. They were the only ones with the rear sump. They also put out around 500 lb/ft torque stock. If you really want to be a bit different on top of that, in 76 they had a fuel injection option.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
05-14-2015, 09:28 PM | #9 |
I know everyone here is probably tired of hearing this but
**cough LS cough** Lot more bang for your buck, lot more reliability. That old stuff is just... old. |
05-14-2015, 10:55 PM | #10 |
Or you can look in a olds or buick big blocks since you want different.
