Cab Rot Around Rear View mirror at Windshield
Hi All! I have a 1971 Chevy C20. Just wondering if this is a major headache to replace my windshield and weather stripping since the windshield is cracked. I have some rusted areas on the inside where the rear view mirror is located ( see photos). This seems like a common problem - any/all advice on what I'm in for appreciated.
Without tearing into it, I don't know if it effects the windshield weather stripping or not. |
The Older Generation
Re: Cab Rot Around Rear View mirror at Windshield
I think there is a patch panel made for that area but I don't know how wide it is. That may be a tough fix. It may not affect the seal but you will have to remove the windshield to repair it. No way to know what you will find under the rubber until you get it out..... LockDoc
Had same problem on my '72 GMC except the rearview mirror is on the window and not on the eyebrow panel. The most important thing in this fix is to determine where the water is coming from to rust this area in the first place. I had a small hole in roof apparently that was allowing the water in. Could be faulty sealer on drip rails allowing water underneath and undetected. I purchased the repair eyebrow panel. I had a body shop do the work since I don't have proper tools and welding equipment. They removed the window, found the leak, and cut out the rusty and damaged metal. They welded in the new eyebrow panel which came with a rearview mirror mounting pad.
'72 GMC short-step 350/350 |
Hi Goose! Any idea as to the cost to weld in a new eyebrow panel? ThX
#5 | |
![]() Join Date: Sep 2004
Roof swap is always an option..
"You can take the man out of PA, but you can't take PA out of the man" |
That looks bad: from what I've read on here, get ready to bust out the pocketbook or get another cab. *I have the same nightmare waiting on me.
Its totally repairable. We'll be wishing more cabs were saved as time goes on. I used to only buy rust-free trucks (meaning no rust ever/not repaired). Good luck with that now
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
http://www.classicheartbeat.com/Patch%20Panels.htm
http://www.classicheartbeat.com/cata...ch%20Panel.htm
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Sorry, cost is tough to estimate because it is part of the entire package. They replaced rocker panels, reskinned doors, repaired the eyebrow panel, installed new cab mounts, removed old paint to raw metal, and will repaint entire truck basecoat - clearcoat. All said and done we're talking in the $10G category. My rationale .... it's still cheaper than a new truck.
Florida Edition
![]() ![]() Join Date: Oct 2010
Mine was 8 K for body and paint with minimal rust repair so your good.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: Apr 2007
Heres a few pics from when I fixed mine. I cut the inside seem about a half inch from the roof indent toward the windshied on the truck and put an offset bend on it with a flang tool so I didn't wind up with a visable overlap and didn't have to weld in a but joint ,worked great. Had to cut a patch out of a donor cab to fix over drivers door though.
#13 |
It doesn't look it but the seem is completely flush after I buffed the weld a bit with a flapper disc.
| Bookmarks |
