Old 05-14-2015, 07:06 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
4 SPD back up switch, Ebay pricey little bas@#*<}
NOS I've seen up to $180 so far. This must be a bargain then.
We need to find a close enough or usable solution.
http://www.ebay.com/itm/AC-Delco-Rem...torefresh=true
Old 05-14-2015, 07:49 PM   #2
pimpston65
pimpston65's Avatar
Re: 4 SPD back up switch, Ebay pricey little bas@#*<}
i've thought about that. the switch from other brands(ford) kept coming up during my search, im sure modification can be made to make it work...
pimpston65 is offline   Reply With Quote
Old 05-14-2015, 09:24 PM   #3
Cooper197
Cooper197's Avatar
I just used a standard momentary switch.
I have a Lokar shift boot over my factory shifter just to make things look nice, so it also covers up the reverse switch. I just got a cheap momentary switch from the auto parts store and ultimately ended up running new wiring to it since the old wiring was pretty munched up, but it's a very easy way to do it.
The only special thing I had to do (besides the wiring, but I don't think that would normally need to be done) was make the whole on the bracket a little bit bigger. Otherwise everything is just as it would have been factory, except the switch is black plastic...and made in China.
I think the whole thing including the wiring was less than $10.
Cooper197 is offline   Reply With Quote
Old 05-14-2015, 10:06 PM   #4
pestwagon
I paid about $50 3 years ago for one....worked every time! Went into the Grey Goose that Delmo restored...maybe he still has the switch?
pestwagon is offline   Reply With Quote
Old 05-14-2015, 10:10 PM   #5
GVDobler
GVDobler's Avatar
Somewhere I saw a good explanation of adding a backup switch, now can't find it. But I did see this, if it helps.
http://www.kinzers.com/don/landcruiser/sm420rev_switch/
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
Old 05-15-2015, 11:01 AM   #6
Dsuper5
Dsuper5's Avatar
Smile Re: 4 SPD back up switch, Ebay pricey little bas@#*<}
Hi guys
here is what i did, Napa momentary switch for 7.99, plus a little drilling and bending and measuring twice.
Dsuper5 is offline   Reply With Quote
