Interior noise inside 2Door Tahoe???
I have a 1999 2door Tahoe and I have a noise that comes from where the passengers feet rest right above them. Under the glove box there is the black plastic box that looks like thats what brings in the heat or ac into the vents. It sounds like the door that opens or closes depending if you are letting in outside air or closing it to not let outside air in opens and shuts on its own. I will hear a sound that seems like it slams shut kinda loud and sometimes it's a lot more quiet than other times. Also hear tapping sounds that are like 3-5 seconds apart, thats how it started. Kind of a knocking sound. And also hear like a faint sound of humming like a electrcal motor noise. Could it be that the motor that opens and closes to let or not let outside air in is going bad? Thanks for any info or help guys.
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe |
Re: Interior noise inside 2Door Tahoe???
Was driving earlier today and pushed the button that lets the outside air in or not and I pushed it to close and not let outside air in but it kept letting outside air in and it sounded like the door for the vent was trying to close but did not Could the motor or switch for it be bad?
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe Last edited by slam59; 05-16-2015 at 06:15 PM. |
blood type; Retumbo
Re circulation door actuator. It has plastic gears that strip giving you that click noise. Have fun, it's a real pita to do
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
68c15 thanks for the info. Yeah I figured it had to do with the control for the inside/outside air. Gonna be a fun one lol. Probably invent some cuss words that day lol
I just had to replace my recirculate door actuator on my '96. It's not fun, but doable. There is NO documentation anywhere for the recirc door actuator, the blend and direction actuators, yes, but not the recirc one. It is directly forward of the blower motor between the hvac box and the vertical portion of the firewall. You can lay down in the passenger foot area, look up, and see it. I want to say it was the usual 7MM interior screws, 2 of them? Maybe 3.
EDIT: Just realized this thread is 2-years old. Hope that info helps someone. I couldn't find much when I was researching my click click click click click underdash.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#6 | |
Thanks for the reply 83 gm! I have not fixed it and have not been here too much and this comes at a perfect time. What all do u have to remove to get to it or is it just a matter of getting under there and removing it?
Posted via Mobile Device |
#8 | |
