LMC cowl vent seals
Has anyone else had issues with the cowl vent seals from LMC? I tried to put mine on today and expected some problems immediately when I saw they were rectangular in shape and don't match the vent. I assume they go on the flange the sits against the cowl?
Any insight from others is appreciated and if anyone knows who has a correct set please post the supplier. Thanks |
Re: LMC cowl vent seals
I saw another post about this. google soffseal. i think you prchase through jegs. it looks right.
soffseal cowl weatherstrip. part# 9017
Thanks for the replies. I will check out Soffseal.
Have a good weekend everyone |
Check out my thread, I found the cure. Z POPPY
http://67-72chevytrucks.com/vboard/s...d.php?t=668116 |
I think there's a misunderstanding here. I'm looking for seals for the cowl vents, not the hood to cowl seal. I've checked Soffseal and Steele Rubber in my new catalog and neither have these seals. I ended up using putty tape for RV's etc.. I think my windshield is leaking too as water runs down my firewall onto the floor in a heavy downpour like we had yesterday.
Thanks everybody |
Another place to check is inside the wheel well.
Where the side kick panel meets the fire wall, there is seam sealer there that cracks and falls off with age. Had to re-do mine as it was leaking there. Easier to do with the fender off but possible with fender on. |
Thanks 65C20. I will check that area as well
Was wondering if you had a chance to check that out ?
You can test it by running your hose on the seam inside your wheel well leaving the windshield dry. |
65c20
Sorry its taken so long to reply, but yeah, I checked the wheel well area, and cant see any cracks or missing sealer. I did see water coming in from the cowl area on the right side on top, so will clean it real good and put some new seam sealer on it. I used that tape like stuff for RV's t seal the actual vents, but haven't had any rain for a week or so to check the seal. I have to clean the under side of my truck to get rid of all the oil so may hit the area with a hard spray but not enough to do any damage to the undercoating. |
