Old 05-15-2015, 10:36 AM   #1
ol'blu72
30deg initial timing!?!?!!
I finally have gotten back in my blazer after only driving it like 3 times in the last 2 years and decided to do some tuning. I set my timing "seat of the pants style" by driving it around town and making adjustments in random parking lots to get the best throttle response and power for all driving conditions. I was the best time I have had in a while. I got her dialed in and she runs great and pulls strong.
So i got her home and decided to check where I was at with my light and to my surprise she is sitting at nearly 30deg initial! I did some revving and mechanical advance is 30deg all in at 3500. This is just strange to me and I am thinking something is wrong. What do you experts think?
Details: Newly rebuilt (1000mi ish) 350 in a 72 blazer. Vortec heads, summit HEI dizzy, the mildest comp xtreme energy cam they got (probably similar to a RV cam). 350 tranny, 3.73 gears.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 05-15-2015, 11:10 AM   #2
68350
68350's Avatar
Re: 30deg initial timing!?!?!!
I'm no expert on this but 30 all in sounds reasonable. My 496 is 36 degrees all the time(distributor is locked out). Did you have the vacuum line plugged on the vacuum advance when you checked your timing? Or is your vacuum advance even hooked up?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 05-15-2015, 11:13 AM   #3
67 chevelle
67 chevelle's Avatar
If its 30 total at arround 2500-3000 rpms thats sounds right . It should be 8-10 inital at 800 rpms vacuum disconnected . Vortec heads are so efficient , they only need , and or run best at around 32 degrees total timing , where as most other small blocks like 34 to 36 total degrees
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-15-2015, 11:14 AM   #4
ol'blu72
No not 30 deg all in, it is almost 30 at idle! My vacuum advance was disco'd and plugged.
Brad
Old 05-15-2015, 11:36 AM   #5
ol'blu72
I just went out and verified, my timing light is actually saying 38 deg initial and at 3500 (that's when the advance stops) I am approaching 60 deg.
Brad
Old 05-15-2015, 11:38 AM   #6
BMERDOC
BMERDOC's Avatar
Do your advance weights move freely? I would also verify that the distributor is stabbed in correctly and not a tooth off.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 05-15-2015, 11:41 AM   #7
ol'blu72
I am assuming so since I am getting about 20+ deg of advance from them. maybe too much but still haven't seen any sign of detonation. How do I verify if i am a tooth off?
Brad
Old 05-15-2015, 11:44 AM   #8
geezer#99
geezer#99's Avatar
Balancer slipped!!
Have you verified timing tab/marks?
http://www.crankshaftcoalition.com/w...op_dead_center
Old 05-15-2015, 12:21 PM   #9
67 cst swb
67 cst swb's Avatar
Originally Posted by geezer#99 View Post
Balancer slipped!!
Ditto
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-15-2015, 12:53 PM   #10
jocko
jocko's Avatar
To answer your initial (pun intended) question - 30 deg initial is waaaay too high. Should be 6-10ish. So, if you're not hearing/feeling ping or detonation, I suspect the comments above are correct. Check the balancer vs timing marks etc for anything obviously wrong. The outer ring with the mark may have rotated relative to the inner hub. If that's bad, replace that bad boy asap. If balancer slip isn't readily apparent, then set tdc on #1 by any method out there besides your timing marks - and compare to see what is shows. It's easy and tempting to set initial timing too high by seat of the pants and your ear because it gives improved throttle response, but at a cost, and risk to engine. Since it sounds like your vac and mech advances are working (30 deg (correction 22 deg) increase from idle to 3500 rpm), really seems like a balancer or distrib install issue. Interested to see what you find out.
Old 05-15-2015, 04:41 PM   #11
67 chevelle
sounds like its time for a new ballencer , no way thats right
Old 05-15-2015, 04:57 PM   #12
ol'blu72
I replaced the balancer on the rebuild so it is brand new. You think the timing mark is just off on the new balancer? I never did verify it.
Brad
Old 05-15-2015, 05:01 PM   #13
geezer#99
geezer#99's Avatar
Never know until you check it.
Could be just mismatched tab and balancer.
What's your idle rpm?
Old 05-15-2015, 05:21 PM   #14
ol'blu72
Never no until you check it.
Damn Autozone! lol
Correct me if I am wrong but I dont think you can be a tooth off on your dist install. In my mind the only consequence of being off would be the indexing of the cap, I would just have to turn it more, one way or the other, to compensate. In theroy i beleive you can install it 180deg off but your cap would just be rotated 180deg also, and would make for fitment issues. Am I way off base??
Brad
Old 05-15-2015, 05:34 PM   #15
Boog
laying low
Boog's Avatar
You are correct. The distributor can be installed a tooth off either direction and as long as you can turn the housing to set timing correctly it is just fine. If say the vacumn canister hits the intake manifold runner before the distributor is turned far enough to correctly time it you can move the plug wires around by one terminal in the opposite direction to give more adjustment.
Being "off by one tooth" does not affect timing as long as you can turn the distributor enough to achieve the correct timing setting at the harmonic balancer timing tab. A lot of people do not understand this.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-15-2015, 06:05 PM   #16
BMERDOC
BMERDOC's Avatar
Ah. The old slipped balancer problem. I forgot about that one. Seems balancers aren't the only thing around here. Haha!
Nick Carter
Old 05-15-2015, 06:09 PM   #17
Custom/Ten
Custom/Ten's Avatar
Damn Autozone! lol
I am beleive this fella is correct. Guess I'm one of those people who doesent understand, tried to install my dizzy one tooth of once would not go all the way in and left a big gap. Perfectly willing to accept that I'm wrong, just sayin.
Custom/Ten is offline   Reply With Quote
Old 05-15-2015, 06:23 PM   #18
Custom/Ten
Custom/Ten's Avatar
Smile Re: 30deg initial timing!?!?!!
Size:  32.1 KB bottom of the shaft appears to only go in 2 ways. I don't get it. Please do explain though. I'm always up for learning some thing new and maybe we can help this gentleman in the process!
Old 05-15-2015, 06:26 PM   #19
Boog
laying low
Boog's Avatar
The reason the distributor won't drop in all the way is because of the oil pump drive shaft. All you have to do is pull the dist back out and use a long screw driver to turn the drive shaft a little bit and drop the dist back in or you can drop the dist in until it engages the cam gear then bump the engine over and the dist will drop on down when the drive shaft lines up right. Easypeasy.
Boog
primer is finer
Old 05-15-2015, 06:32 PM   #20
Custom/Ten
Custom/Ten's Avatar
I've heard not to bump the motor when the dizzys out so yea I'll buy that. Thanks
Old 05-15-2015, 07:09 PM   #21
geezer#99
geezer#99's Avatar
And it's always good to pass a file over the sides of the tang to clean off any small burrs. Especially on a new dizzy. I've had them too tight to drop into the oil pump slot.
Old 05-15-2015, 08:15 PM   #22
Ruscal
Is timing light clipped to the number 1 plug wire? That would throw it off more than 20 degrees though if you were on the wrong wire.
Russ
Ruscal is offline   Reply With Quote
Old 05-16-2015, 12:01 AM   #23
jocko
jocko's Avatar
I think it at this point, you really need to:
1) find TDC (not via the timing marks)
2) check to see where your balancer 0 line is relative to the timing pointer
3) if all that's good, look at the distrib and make sure that the rotor is at or slightly past the #1 tower
Old 05-16-2015, 01:09 AM   #24
mechanicalman
Get one of these and find TDC:
http://www.summitracing.com/parts/sum-900189/overview/
Then determine what timing tab you need to match the balancer you got or if the mark is defective on the balancer. See pics below.
After finding TDC you could always just install timing tape the right size for your balancer and fix it that way.
http://www.summitracing.com/search?S...0Timing%20Tape
http://www.summitracing.com/parts/mr...make/chevrolet
If you get a new pointer make sure it's right for your size balancer. They also make sleeves to go over the balancer (dress-up) but they are degreed and never slip.
http://www.summitracing.com/search/p...ancer%20Covers
Many ways to fix this, but you need to start with the piston stop. Go easy on it, if you yank too hard on the crank you will bend it but that's not necessary.
mechanicalman is offline   Reply With Quote
Old 05-16-2015, 02:00 AM   #25
BMERDOC
BMERDOC's Avatar
Geeze, what a typo. "aren't the only thing SLIPPING around here".
Nick Carter
