05-15-2015, 10:45 AM | #1 |
1962 Factory frame X-brace
Hello all! Newbie here and thank you for all the great info I have gotten so far hope someone can help with my question below
I removed the front suspechion in my 62 and installed a K member from a 78 so no more torshion bars. Has anyone removed the factory X bracing from the 60-62 frame and just boxed it or add a few smaller braces to make it like a 63 frame? |
05-15-2015, 01:53 PM | #2 | |
Re: 1962 Factory frame X-brace
1) The frame is a very good design as it stands 2) The 63 frame has a different spacing between the frame rails 3) I think the 63-66 frame is taller and possibly heavier gauge than the 60-62. Removing the x brace from the 60-62 frame and boxing it would result in a frame that doesn't have very good structural integrity. If you want a 63-66 frame, get a 63-66 frame. It's going to be better than trying to modify the 60-62 frame.
We'll burn that bridge when we get there My current project: Rust Therapy 62 C10 Numbers 6:24-26 |
05-15-2015, 01:59 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Welcome!
Ditto as 53sparky said!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-15-2015, 02:11 PM | #4 | |
05-15-2015, 02:12 PM | #5 |
05-15-2015, 02:40 PM | #6 | |
Seriously, your exhaust will run under the frame rails on either side identically to how they were originally done just fine.
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
05-15-2015, 02:49 PM | #7 | |
05-15-2015, 06:38 PM | #8 |
This was shared and cleaner than mine. But the new stuff will bee that clean.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-15-2015, 10:57 PM | #9 |
Hope my 62 looks half that good underneath when it back together. Question, what is the advantage in the cross in the exhaust?
05-16-2015, 12:47 AM | #10 | |
1961 crewcab
http://forums.vintage-mustang.com/vi...-pipe-all.html
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-16-2015, 09:40 AM | #11 |
It balances the pressures in the pipes. You don't need it but Pypes sells this and is cheaper than having one built. Here is mine I sold. Only few years of use. Not connected in center. You need to pass through the center of torsion crossmember.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 05-16-2015 at 09:46 AM. |
05-16-2015, 09:43 AM | #12 |
05-18-2015, 01:43 PM | #13 |
"Where were you in '62?"
I did! ;-)
Here is an old picture. Done alot more since the photo.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
05-19-2015, 02:57 PM | #14 |
05-19-2015, 02:58 PM | #15 |
Thank you all for the help! The photos of the exhaust routing with the X in the frame is very helpful
05-19-2015, 04:04 PM | #16 | |
She's got a few more tinkering to be done and she will be back on the road. http://67-72chevytrucks.com/vboard/s...d.php?t=321173
05-20-2015, 04:24 PM | #17 |
On these frames has anyone found a good rear gas tank that works well? I believe I remember hearing about a Ford Falcon tank that fit.
05-20-2015, 08:58 PM | #18 |
Corvette, Mustang / Falcon. TANKS INC.
http://www.tanksinc.com/index.cfm/pa...rod/prd155.htm
06-03-2015, 01:29 PM | #19 |
LVPhotos, what did you have that exhaust system hooked to. Headers or manifolds. And did the truck have the factory bell housing cross member in it?
06-03-2015, 01:34 PM | #20 |
I got one from POI, works great, pricey as hell. But I didn't know about the corvette one... :|
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
06-03-2015, 03:30 PM | #21 |
Original was ram horns and side pipes. Went to Patriot shorties and exhaust as you see. Stock hydraulic bellhouse with arm on passenger side. New stuff... Mid headers won't clear arm, so I am in middle of TKO 600 swap and hydraulic bearing as seen on build thread listed below.
06-03-2015, 04:44 PM | #22 |
06-04-2015, 03:09 PM | #23 |
Sent you a PM LVPHOTOS, got a couple questions for you.
06-04-2015, 06:29 PM | #24 |
I'll be in on that one for my 61, as I like to have GM OEM if at all possible !
Living The Canadian Dream in British Columbia |
