lowerd shocks
Here is a quick question for all the people that have lowered their 67-72 with coil suspension.
I ordered 4" lowering coils on Friday and also got an adjustable panhard bar coming. What did evrybody use for lowered shocks?? I was going to try and get the specs for the factory shocks and then just get something shorter, but how short. I know the belltech shocks are the same for anywhere from a 2" drop all the way to 5" drop. I know most parts stores acrry evryday shocks for cheaper than belltech ones. Any suggestions??? BTW I have a 69 Fleetside LWB
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
Pronounced "Pew-al-up"
I installed the bell tech shocks and am very disappointed in them.
The back of my truck has rattled since I installed them, and they really arent very strong.... IMO ![]()
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
Low & Slow
Stock replacment shocks here... straight from the auto parts store. lol.... I have the same rear setup that you are going with btw.
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
By using the stock shocks, isn't the ride a bit worse and can they handle being 4" lower all the time???
ttt
With almost 100 views, there has to be someone else that has gone with shortned regular shocks from an autoparts store???
How much shorter a shock do I really need???
Fabricate till you "puke"
you might think about a shock relocator kit(stands the shock back up), & I beleive moves the bottom position a tad lower. the stock shocks should work that way. You might try GMC Paul on the kit. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Yeah I was thinking of doing that ( relocate the shocks). I am probably going to get them from the same company that I get my drop spindles from. I was looking at gmcpauls site yet again and am trying to compare all the different companies that sell them ( drop spindles) and checking shipping costs, ( have to ship up to the great white north).
I used the KYB gas shocks with shock relocators ...
Running Doetsch Tech.
Haven't put in the relocaters or adj. panhard yet. Rides great - Doetsch Tech is much better then Bell Tech's Nitro Drops
Jimmie Modern Vintage Autoworks - '70 Chevy C10 - '74 Chevy C30 3+3 Dually - '04 Chevy Colorado Built, NOT, Bought. If you build it...they will ENVY! Drive Slow, Scrape Hard, or Take Your Truck and GO HOME! |
Thanks for the input, I am currently waiting on the adjustable panhard bar ( should be in tomorrow) and the 4" drop coils ( should also be in tomorrow).
Once I get those installed I will see what the shock situation is. I don't drive the truck all that much right now ( out of town every week for work) so just plain cheap shocks will do for now ( just curious how much shorter I will need). But if I get the relocators I shouldn't need to get lowered shocks right?. Once I get more $$$ saved then who knows bags me be in the picture.
Keepin an eye out
I asked this before, does anyone use air shocks?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#13 |
I have a 3/5 drop on my longhorn, & run stock lenght shocks(Monroe gas), on relocators both ends. My longhorn is a slightly different deal(leaf rear), so i had to make the shock reloactors....I dont have any problems with the ride tho.... good luck, crazyL
#14 | |
Low & Slow
#15 |
Cantankerous Geezer
Just finished mine over the weekend. Drop spindles on the front with stock Gabriel gas shocks, 3" drop springs on the rear with Doetsch Tech, relocator kit and adjustable panhard bar on the rear. Got it aligned today and the ride is great. The relocator is a must have, greatly improves the geometry for a smoother ride.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#16 |
Thanks for all the input. Looks like I will be getting some relocators along with spindles, since I already have 4"drop coils and an adjustable panhard coming.
I will be contacting a few vendors to see what cost+shipping will be. Of course it will be the vendors that are members here.
#17 | |
COMING SOON...
#18 |
call early classic enterprises, they'll hook you up... and not to mention, they have to be one of the best companies I have ever dealt with!
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
#19 | |
#20 |
shocks
as far as the front goes the spindles will not afect the space of the shocks but springs will, i have factory style shocks on my truck with 3 inch spindles and 2 inch spings in front and 6 inch springs in the rear it still rides pleny good. but i dont anythin but azz in my truck....Steve
#21 |
I'm using KYB gas-a-adjust in the front and Early Classic's KYB G2s in the rear with the relocators and adj. panhard bar. I tried the EC KYB up front but is was too soft on both rebound and compression. I am very pleased with my current setup. By the way I have a 3/5 drop.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
#22 | |
ECE is by far the best Company I have worked with since I have been working on my truck! ![]()
![]() 350/350 3.73 Next; 335hp GM Crate |
#23 |
Do you guys know if ECE will ship to Canada??? Seems I tried to get a quote from one of the vendors here and he will not sell to Canada. That will be one bookmark I will definetly get rid of.
I must say thanks to Mothertruckers who did send me a quote fairly quickly and will sell to me. The other vendor will only sell to a US address, great I can get it shipped to a US address but it is still in the US and would have to pay to get it shipped to canada. I think that if a vendor will not sell outside to us in Canada then he should no longer have his link on the site. I have spent alot of time on the site making a list of stuff and now I will not be getting from him. The reason was because there are to many credit card fraud and people not paying. Sure whatever. I was really surprised to get the email from them. I was not happy at all and WILL MAKE IT KNOWN. Especially since they are a member here. Sorry for the long post but I have been waiting for about 4-5 years to get started on my truck and now this. Just had to vent. At least I know SOME companies are still willing to be a company and sell to people. So once again thanks to Mothertruckers and to the other vendor ![]() ![]()
#24 |
Low & Slow
Man... that's not right, He has his reasons whoever he is. If they won't ship don't get all pissed off about it. Who are you to say if they are BSing y ou about credit card fraud? Sorry that's just my .02
#25 |
I am pissed at the fact that once again we ( Canadians) get screwed cause people don't want to sell to us. I never said they were BSing me about the credit card fraud cause we all know it is everywhere, but to only sell to the US and not Canada is wat I think is just not right.
If you want to be in business then sell, if you refuse to sell then rethink your business. It's bad enough that we have a hard time getting some stuff up here, I didn't think that a vendor from this great forum wouldn't sell to Canada. Put yourself in my place and say the same thing.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags Last edited by GMC69; 09-05-2003 at 12:29 AM. |
