05-15-2015, 11:42 AM | #1 |
Tilt Steering Column on eBay..
I found this column on eBay from an old thread on here, just wondering what I would have to fab up to actually make it functional on my 62 c10.. I am going with a automatic floor shift..
Any advice would help, I don't want to pay for a $600 tilt column.. I also know the saying 'you get what you pay for' but I just want it to be functional and do it's job for cheap. Thanks |
05-15-2015, 12:23 PM | #2 |
Re: Tilt Steering Column on eBay..
You'll need an intermediate shaft from a 69-72 (maybe later) to connect the column to the steering box. I used the original firewall clamp on my 64, and used a HD hose clamp on the interior side. you'll need to redo the turn/horn wires from the column to the harness since different connectors are used.
05-15-2015, 01:51 PM | #3 |
Thank you, I should've given more info, I just bolted up my 72 front crossmember swap with the power steering pump (haven't figured the mounting for the pump yet though) and I'm doing a whole wiring harness swap. I think it's the American Auto Wire.
05-15-2015, 01:51 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
Contact Kev's Classics here on the board, he may have what you need and it will be top notch!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-15-2015, 03:27 PM | #5 |
I used an 70's GM column. I adapted it to my 65 steering shaft by cutting the shaft and grinding it into a double D. I used a Flaming River U-joint DD x splined to link it to the steering column.
Many chinese made tilt columns are not safe for use. The factory GM columns employ a failsafe joint that will not leave you without steering. Other name brands like Ididit and Flaming river use laboratory certified and serialized construction methods that are safe. I bought a "pro-header" brand and then asked the importer if they employed a safe design. He acted interested in my email, but then probably found they were unsafe, because he stopped responding. Here is a link: http://www.lvvta.org.nz/documents/in...ng_Columns.pdf If you have a V-8, Bills Bracket company makes a good power steering bracket for a late 70's pump with a bolt on pulley. Speedway Motors sells this stuff. It is all I use. If you have decent electrical skills, you can save a ton of money by buying a marine(boat) style fuse block and then just lay in your own new wires. Last edited by wildearp; 05-15-2015 at 03:33 PM. |
05-15-2015, 04:10 PM | #6 |
I put a 70's van tilt column in my 65 and I keep it in the reg steering position and never really tilt it. Go figure.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
