05-15-2015, 02:52 PM | #1 |
homemade tilt hood video
Subject:Watch "67-72 homemade tilt hood" on YouT, https://youtu.be/9kogRMi0ue0.
Well the shocks drastically help the ease to open and shut the hood. I need to make some brackets to hold springs and limit how far forward the hood can turn so it won't hit the grille. Thought someone may want these ideas
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
05-15-2015, 07:09 PM | #2 |
Re: homemade tilt hood video
Great job man.
05-15-2015, 07:12 PM | #3 |
Cool man, thanks for the "ideas"! Can I have the motor too!
05-15-2015, 07:22 PM | #4 |
6>8 Plugless........
Great work! I bet that took some trial and error to get working that easily!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-15-2015, 10:35 PM | #5 |
Yes sir, many trials but works good now. I have less than 100$ in the setup
05-15-2015, 10:49 PM | #6 |
That's very very cool! Nice and clean! Great job!
http://smg.photobucket.com/albums/v655/aaronhero/ |
05-16-2015, 06:34 AM | #7 |
That is completely different from anything i've seen. great job!
Go BIG or GO home!! 1970 Custom Chevy C10 / 350 bored .30 over / 5.5/7 drop on 20" boss 338 |
03-16-2016, 03:39 PM | #8 |
Nice job man!
03-17-2016, 10:26 AM | #9 |
That's Sweet! Great job!
Ben |
01-14-2017, 05:20 PM | #10 |
robznob11
this is awesome!! do you have a how to build on this? |
01-14-2017, 05:50 PM | #11 |
Looks like it works pretty damn good
______________________ www.northeastrodrun.com |
01-14-2017, 07:10 PM | #12 |
Old member
Very nice sir! Well done.
01-14-2017, 08:23 PM | #13 |
Sir. I dont have a build on it but i can get some pics and some measurements in a day or two and post up. It consists of maybe 1-2 foot of 1 1/2 angle. A stick of small square tube and a little bit of plate . Oh and a couple of eye bolts i welded on the ends. They were for a fence gate from tractor supply. It was just trial and error till i got it right. I can get you in the ball park for sure. One thing to note. The aftermarket hood has two braces that runs parallel down each side of the scoop. Stock does not so it may not be as easy with a stock hood. With that said i built slider brackets for under the hood so i do have alittle adjustment if needed. Also allows the bracket to be removed pretty easy. The rear latches i cut the top section of the oe hinges. That allows me to bolt those brackets in the oe holes and stack shims to raise or lower the back as well. When the back sliders fall into the slot and the oe front latch is engaged it is positively locked down front and back. The rubber isolaters keep it located for the most part between the fenders.
01-14-2017, 08:26 PM | #14 |
Also i abandon the springs and went to a prop rod to keep it off the front end. Ill get pics of it too
01-14-2017, 10:56 PM | #15 |
That is certainly trick, any wind will wreck your day though.
01-15-2017, 12:15 AM | #16 |
Um i assum you mean a windy day with it open. Cause when its closed its not going anywhere. I did this mod caus my truck will go low enoug that it would hit stock hinges. It is more sturdy than you think. You can also prop it @ 2/3 open the normal way.. if you extended the rear catch you could probably get mor than that.
01-15-2017, 11:12 AM | #17 |
Wow.
And to think I was excited installing new bumper stops under the hood the other day.
Hook'em |
01-15-2017, 02:23 PM | #18 | |
