Old 05-15-2015, 11:35 PM   #1
Mapearso
Help with My Incomplete A/C System Please!
So I have an A/C truck. All of the interior parts are there-- control unit, ducts and vents
BUT...
Under the hood is missing some stuff... and I'm not sure what. I know for sure I need a new compressor and the bracket 'cause that ain't there. But I have no clue what else is missing...
I have posted pics. If someone could please be so kind as to list everything I need I would really appreciate it. By the way the motor is a 454.
Thank you
Mapearso is offline   Reply With Quote
Old 05-16-2015, 06:05 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Help with My Incomplete A/C System Please!
Do you have the condenser, drier and pipes in front of the radiator?
You look to be missing the compressor, brackets and hose assembly
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-16-2015, 09:31 AM   #3
Davidf
It appears that you are missing compressor and related brackets, hoses, and I don't see the pipes from/to condenser/dryer sticking out from under the batter tray. Most of the parts are available from Classic Parts who get them from Old Air Products or Vintage Air.
Davidf is offline   Reply With Quote
Old 05-16-2015, 01:04 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
Due to the fact that the photo shows the alternator on the passenger side, i would assume that an engine swap was performed, since originally the alternator was on the driver side on 67-72 trucks. Not a big deal, you just need to be sure you get the parts to fit your engine. No point in buying original set of brackets for a 67-72, only to have them not fit.
WIDESIDE72 is offline   Reply With Quote
Old 05-16-2015, 01:11 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
I have a 79 malibu that i am swapping a 73 454 out of a c20 into. The ac compressor and brackets were missing. Instead of the big heavy stock a6 comressor, i am considering this:
http://m.ebay.com/itm/360525928843?nav=SEARCH
I just contacted them for there advice on hoses, as the end at the compressor is different.
Old 05-16-2015, 08:27 PM   #6
Mapearso
thanks.
yes, per above it has a 454 transplant
Old 05-23-2015, 09:46 PM   #7
Mapearso
Should I be grabbing this stuff off a parts truck?????? It's a '71 with A/C, no compressor but some other stock bits (I believe)
Old 05-23-2015, 10:31 PM   #8
fat dan
Should be a manual or vacuum water shut off valve between engine and heater.
fat dan is offline   Reply With Quote
Old 05-23-2015, 11:01 PM   #9
Mapearso
Understood. But I'm asking if these A/C parts in the would be worth pulling off a local parts truck??? I'm missing them so I think I should??
Old 05-23-2015, 11:03 PM   #10
fat dan
To add. I would get all of the connectors, tubing, mounting brackets, and fittings. If hose is in good shape you can flush them out as long as it doesn't have a muffler assembly. If it has a muffler then you need to get a new one. They have flushes for the evaporator. I would use a new condenser, receiver drier, and expansion valve. Some people on here have had luck using old parts and some have not.
Old 05-23-2015, 11:08 PM   #11
fat dan
If you don't have the tubing that's under the battery tray be sure to get that.
Old 08-09-2015, 10:13 PM   #12
Mapearso
Got a compressor and related hoses at the yard. Here's what I have now --
Old 08-09-2015, 10:19 PM   #13
Mapearso
and under the hood still looks like this
So I know I need brackets.
What else??
tHANKS!!!
Old 08-10-2015, 03:44 AM   #14
F.A.A.benny
You should restore that ac box. Or at least check to make sure there isn't any rodent crap, insects, or a bunch of leaves.
F.A.A.benny is offline   Reply With Quote
Old 08-10-2015, 07:27 AM   #15
jjzepplin
jjzepplin's Avatar
Why no muffler? What does it look like?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-10-2015, 11:02 AM   #16
Davidf
If it was me, I would do the following:
1. Salvage the condenser, hard pipes, and receiver/drier mounting clamps from the donor.
2. Purchase new hose assemblies.
3. Forget about any salvaged A6 compressor...it will probably be worn out and rebuilding it will probably just end in a leaky front seal. Instead, purchase a new Pro6Ten compressor...a direct bolt in replacement and lighter. Get the compressor mounting brackets from the donor.
4. Get alternator brackets to move alternator to other side of engine. Or, get compressor brackets for left side mounting and have custom a/c hoses made. Many GM cars/trucks had a/c compressor mounted on left side of engine.
5. New receiver/drier.
6. New expansion valve
7. Check POA valve and (check) calibrate for R12 at 29.5 psi.
8. New heater water valve...normally open (i.e. vacuum closes valve).
9. Remove evaporator and have a/c shop pressure check with nitrogen. Pressure check the condenser as well. Have them reverse flush both. Ensure POA does not have trash in it from being left open.
Hope this helps. Also, the above assumes you are staying with R12. If you convert to R134a, you will need larger condenser, calibrate POA to 26 psi (I think that is correct, look it up) and then definitely replace the compressor as the higher head pressure will surely cause the front seal to leak on an old A6 compressor even with new seal. But, in LA with the mild summer temperatures, you might get away with using R134a with the original condenser meant for R12. Good luck.
Old 08-10-2015, 02:06 PM   #17
ERASER5
ERASER5's Avatar
I agree with most of this right up to the POA valve. I say get rid of it. Old Air Product has an elimination kit. Unless you plan on smuggling R12 in from Mexico, set this up for R134A. 26 psi cutoff is OK, I went to 20 psi, but on some nights I would freeze over my evap.
Reusing parts that cannot be flushed is asking for trouble. Things like compressors, receiver/dryer, expansion devices should be replaced.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-10-2015, 03:24 PM   #18
Davidf
Oh no no no, do NOT use the POA elimination tube. I tried it and it was the worst decision I made and caused me to waste an entire system charge of R12. The POA elimination tube cause the compressor to cycle excessively and you definitely notice the reduction in air temp each time the compressor cycles off. Having the compressor continuously cycle on and off is VERY irritating. Also, if still using an A6 compressor, you will wear out the clutch prematurely...they were not designed to cycle on and off as much as the POA elimination tube causes.
Old 08-10-2015, 10:24 PM   #19
Mapearso
3. purchase a new Pro6Ten compressor...a direct bolt in replacement and lighter.
7. Check POA valve
Hope this helps. Good luck.
Thanks. Yes -- This is super-helpful
Based your advice above, I am looking at buying a bunch of new stuff.
This makes me wonder whether I am better off, financially, just buying a Vintage Air kit or something similar?
I REALLY would like to keep the truck stock and buy stock replacement items, but this is not a price is no object build, and I wonder if the cost of these parts individually will cost me as much as a kit that might work better?
Thanks again for the advice!
Old 08-11-2015, 08:51 AM   #20
Davidf
I was in the same boat as you and elected to rebuild the factory system. The factory system has air blending, outside or recirc air. The aftermarket systems do not. Nothing against the aftermarket systems as I used one in my 1952 1/2 ton build, but they are just not as integrated as the factory system. Also, I think in the end the money spent will be about the same. And, what to do with all the factory A/C stuff that is abandoned...I think it will look like a cobbled together mess. With all that said, maybe Old Air Products or Vintage Air has an under hood kit that integrates with factory evaporator. But, if it includes the POA eliminator tube, stay clear or you wont be happy.
Old 08-11-2015, 10:46 AM   #21
ERASER5
ERASER5's Avatar
I mentioned Old Air as a possibility. I prefer a standard expansion valve. The H-block type are OK but a retro fit to an H-block is not for the non-refrigerant tech types. Too many special fitted parts.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 08-11-2015, 12:03 PM   #22
leddzepp
Moderator
leddzepp's Avatar
Whatever route you choose, do not use an a6 compressor as it WILL leak eventually.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-21-2015, 02:01 PM   #23
F.A.A.benny
He has to be referring to the muffler/manifold that bolts on to the compressor. But I don't believe there is any baffling in that particular muffler so it could be just flushed very well. I would be more concerned with the hoses as they have pretty good bends on them and being factory original, they may be brittle/dry rotted. They could leak with 134a, being that they aren't barrier hose.
Old 08-21-2015, 02:37 PM   #24
WIDESIDE72
WIDESIDE72's Avatar
Can you expound on this point please. I will be trying to get the factory ac in on of my trucks going and j dont see why this is pertinent.
Old 08-21-2015, 03:36 PM   #25
F.A.A.benny
I think his point is that he has two choices here. He can either stay with his alt on the pass side but will have to mount the comp on the dr side and have a hose set modified to work with the other factory parts or swap the alt back to the dr side, and everything would be a bolt-in deal as
