Old 05-16-2015, 01:04 AM   #1
CarterD2015
CarterD2015's Avatar
Should I try and salvage?
Should I try to salvage this core support, purchase a reproduction or try to find a good original? It is rusted under the battery tray but the rest is in good shape. I am inclined to repair this one. What do you guys think?
CarterD2015 is offline   Reply With Quote
Old 05-16-2015, 01:07 AM   #2
CarterD2015
Re: Should I try and salvage?
Another pic
Old 05-16-2015, 01:08 AM   #3
Ozzy2013
Ozzy2013's Avatar
Totally up to you personally id replace
Ozzy2013 is offline   Reply With Quote
Old 05-16-2015, 01:16 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
There's a patch panel for that lower flange where the inner fender bolts up. If that's all that's wrong with it and you can't find a decent oem support, Id fix what you got.
Tyler
57taskforce is offline   Reply With Quote
Old 05-16-2015, 07:44 AM   #5
hugger6933
It looks like a good candidate for the patch panel that is offered for that spot. I bought three of those panels to work on some of my core supports, I had them "stored" outside the shop and some body "relived" me of them so now I am three supports short from the jump on my projects. The one you showed should fix pretty easy. Jim
hugger6933 is offline   Reply With Quote
Old 05-16-2015, 08:22 AM   #6
Eddie H.
Eddie H.'s Avatar
That's a common problem. I have fixed them pretty easily by just cutting out the rust and welding in new metal.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 05-16-2015, 08:48 AM   #7
Jason Banks
Jason Banks's Avatar
That's definitely a repair that comes down to Time VS Money. If you have more Time than Money I would fix it. If you have more Money than time I would replace.
My core support looks the same way. I am torn between spending the $200 on a new one or fixing the old one.
Jason Banks is offline   Reply With Quote
Old 05-16-2015, 09:34 AM   #8
Jason Banks
This thread got me thinking.
I found the patch that Brothers offers - http://www.brotherstrucks.com/prodin...number=RSP72RH
Looks like they only offer it for the battery side. And it's $70
My support is rusty on the bottom of both sides. I was just going to bend up some patches. But now I'm thinking, it might just be better to buy a new support.
Old 05-16-2015, 10:30 AM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
I fixed mine, actually it was my first ever patch panel. But I fabed me a piece myself just flat stock with a bend. I just used a vice to bend it.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-16-2015, 10:42 AM   #10
CarterD2015
Thanks for the input. I am going to fix the one I have. A remanufactured one would be easiest but I worry about the accuracy of a reproduced part. I know that one one I have is straight and everything fits together well.
Old 05-17-2015, 07:50 PM   #11
bean
I have a 72 core support could give you if you can work out picking it up.
bean is offline   Reply With Quote
Old 05-17-2015, 07:54 PM   #12
In The Ten Ring
If I knew how to weld, I'd fix my rusty core support too. I bought one from a forum member out of CA two years ago and had it shipped in. I hope to install it in the coming weeks.
KUDOS to you for salvaging old iron.
*I am set to take a welding course this summer.
In The Ten Ring is offline   Reply With Quote
Old 05-17-2015, 08:26 PM   #13
CarterD2015
Thanks I appreciate it. I have a good 72. I am under the impression that the 68 is different. I haven't looked at it closely enough to know what those differences are though.
Old 05-17-2015, 09:38 PM   #14
In The Ten Ring
I have read that the 68 is different......when the front clip style changed in 69 so did the radiator core support.
Old 05-17-2015, 11:55 PM   #15
bean
I have a 68 as well you could pieces from
