Old 05-16-2015, 07:58 AM   #1
bbbc10
Diggin The SquareLife
shaved firewall
ok ima be shaving my firewall here soon, an I wana know what have everyone has done with the fuse block on the firewall by the steering column? please share pics an info or links. thanks
bbbc10 is offline   Reply With Quote
Old 05-16-2015, 03:21 PM   #2
tinydb84
tinydb84's Avatar
Re: shaved firewall
I am interested in seeing what people have done too.
David
Instagram: myfabguy
Old 05-16-2015, 07:26 PM   #3
bigblock73
yeller
bigblock73's Avatar
Re: shaved firewall
I built a box to cover my Painless 73-87 harness in my old 73. I actually sold these too for a while, but no longer do. Here are some pics before paint...it was painted body color after the photos were taken, and I changed the design so all the wires exited the bottom and were covered in loom. Harness headlight section ran inside the drivers fender to the core support, completely out of sight.
bigblock73 is offline   Reply With Quote
Old 05-16-2015, 11:09 PM   #4
bbbc10
Re: shaved firewall
looks good...might have to try an fab something up like that
Old 05-16-2015, 11:47 PM   #5
andrewmp6
Re: shaved firewall
Or get a universal wiring harness and mount the fuse block anywhere you want to put it.
andrewmp6 is offline   Reply With Quote
Old 05-17-2015, 07:58 AM   #6
bbbc10
Re: shaved firewall
I don't think im going to go that way....pretty sure there is a few more options
Old 05-17-2015, 09:04 AM   #7
v30crewcab
v30crewcab's Avatar
Re: shaved firewall
speedway has a nice 21 circuit harness for 164.00. it doesn't go thru the firewall like that. then you can just route your wires werever you want them. more work to rewire though. just depends on how smooth you want it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-17-2015, 11:48 AM   #8
Man With A Gun
Man With A Gun's Avatar
Re: shaved firewall
What is a shaved firewall?
Man With A Gun is offline   Reply With Quote
Old 05-18-2015, 02:48 AM   #9
bbbc10
Re: shaved firewall
what ya think bout just extending the wire....maybe just as much work as rewiring it..im jus gonna have the brake booster/master cylinder on the fire wall
Old 05-18-2015, 02:51 AM   #10
bbbc10
Re: shaved firewall
this is a shaved firewall
Old 05-18-2015, 12:26 PM   #11
silverbear
silverbear's Avatar
Re: shaved firewall
I have a buddy that shaved the firewall in his 70 C10. He cut the section out of the fire wall where the bulkhead connector mates up to the back of the fuse block and welded that piece inside the truck. Then he patched up the hole with sheet metal and routed all of the wires out the side of the fire wall and into the cavity of the fender. I know that his generation of truck has more space between the side of the fire wall and the fenders than our generation does, so you could run the wires down through the lip of the fire wall (like the parking brake cable routes) and that should hide your wires between the fire wall and the inner fender. Just an idea.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
