Old 09-02-2003, 09:35 AM   #1
superchevy
Got big-block?
superchevy's Avatar
widest rear rims/tires with a stock stepside fender..ideas/pics?
I've decided not to mini-tub Project Daisycutter, but would like to get some ideas/pics from other stepside owners of how to cram as much meat under those stepside fenders as possible.
Anybody roll the fender lips in for an extra inch of clearance?
What size rims, backspacing are you guys running?
Thanks for the help, SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 09-02-2003, 10:40 AM   #2
chaptr2
chaptr2's Avatar
Here is a picture of my stepside with 15x10 rims in the rear. I have 275/60/15 tires without any clearance problems or having to roll my fenders.
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 09-02-2003, 10:45 AM   #3
chaptr2
chaptr2's Avatar
Here is another look at my wheels and tire.
Old 09-02-2003, 12:26 PM   #4
nosto
Flamin' Bass
nosto's Avatar
superchevy -
255/45X20s on 20X8 rims, 4 1/2" backspace.
With this tire, I can tuck rim (wellll, real close). I have about 3/4" clearence to the bed side and 1/4" to the fender. With bags dumped and frame laying on the axle (about a 3" notch), I still have 1" space from tire to top of fender.
Yes, I pinched the fender just a little because when I only filled one rear air bag, it would catch on the other side. Now, no problems.
As chaptr2 shows, you can get a lot more tire under there if you stay stock or have a mild drop. Just depends where you're going with your project....
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 09-02-2003, 04:15 PM   #5
superchevy
Got big-block?
superchevy's Avatar
Thanks for the info guys.
I've got a 6" drop in the rear.
I'm wondering if I measure very carefully, roll the fender lips, and get a custom offset/backspacing combo, if I can squeeze a 12" wide rim under there?
We'll see. SC
build thread
build thread
Old 09-02-2003, 04:38 PM   #6
SCOTI
SCOTI's Avatar
SC, why did you change your mind about the mini-tubs?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-02-2003, 07:27 PM   #7
superchevy
Got big-block?
superchevy's Avatar
Hey SCOTI. I'm going to keep the bed stock with a nice wood/stainless combo. Just hated to cut it up.
Are you going out to the Ballpark swapmeet this weekend?
Maybe I'll see you there.
SC
build thread
build thread
Old 09-02-2003, 08:52 PM   #8
low 84
low 84's Avatar
i'm betting you won't be able to fit anything bigger than a 15x10 with like a 295 with out mini tubs.............not positive, but i haven't seen any truck with stock wheel wells tuck wider than a 295 without mods
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 09-02-2003, 10:10 PM   #9
SCOTI
SCOTI's Avatar
Yep.... I'm going to try & make it. I also agree w/low84, 10" is max size w/o having to start cutting.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-02-2003, 11:28 PM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
I don't have a step side bed but from what I've heard from people who have them, an 8" wide wheel is about all you can fit with a decent tire. Like Nosto stated he only has about 1" total clearance. That's a pretty tight fit!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 09-03-2003, 09:23 AM   #11
Bowtie468
Bowtie468's Avatar
superchevy, i'm running a 12" wheel in back, and will have to mini tub it. If the stock wheelwells were about 1" wider it would have made it.
Just noticed you've got a step bed. Not sure about the clearance there, i would have to say the same or maybe even a little less!
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 09-03-2003, 09:42 AM   #12
SCOTI
SCOTI's Avatar
SC.... I've got a sawzall & I'm not scared.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2003, 09:09 PM   #13
oldtrucknut
67-72 truck surgeon
Don't be scared, cut it... it's only metal.
15 X 14 w 33 X 19.5
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
Old 09-03-2003, 09:49 PM   #14
superchevy
Got big-block?
superchevy's Avatar
I'm not afraid to cut it, it just opens a can of worms if you do - cutting the bedsides, trimming the bedsills, trimming the wood and bedstrips to fit, etc - for just a couple of more inches of tire. I think maybe it's better to either go for full tubs like ProStreet, or just maximize what you've got stock. I'm not building a ProStreet truck, so I'm just going to work with what I have and squeeze the largest possible sum'***** in that wheelwell.
SC
Old 09-03-2003, 10:00 PM   #15
Randy70C-10
Randy70C-10's Avatar
chaptr2- Hope you don't mind me using this pic
I believe that you can use 12 inch rims with a 6 inch offset, but you'll have to get rid of these and you have to use mini tubs as well.
Randy70C-10 is offline   Reply With Quote
Old 09-04-2003, 12:01 AM   #16
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
I've got 285/70R15's on 15x10 rims. I don't know the back spacing though. I wish I could find a ncie 295/60 somewhere without spending alot of money. I've got BFG Radial T/A's right now. And unfortunately, I don't have a good pic of the rear tires right now. But the 285/70's are about perfect size for my truck and stance. Plus I've about got the tired worn down to some nice street drags.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 09-04-2003, 12:06 AM   #17
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Blackhawkdc - Does anyone make a 295/60 tire...I have 295/50s on my truck now and they look a bit small.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 09-04-2003, 07:24 AM   #18
70c10
67-72 Addict!
70c10's Avatar
I am also curious about dropping the rear of my truck 3-4 inches and getting the widest tire possible to fit. ttt
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-04-2003, 07:44 PM   #19
Blackhawkdc
440 american Horses
BFgoodrich makes a 295/65R15 or a 315/60R15 in their Comp T/A Drag Radial tire. That's the only one I've found so far
Seth Petro
Old 05-29-2012, 08:21 AM   #20
mmathews
Re: widest rear rims/tires with a stock stepside fender..ideas/pics?
I am trying to do the same thing on my 70 stepside.I want the biggest wheel in the rear without cutting anything. The front i just want to run a 17 or 18 but do not know what back spacing should be. any suggestions.
mmathews is offline   Reply With Quote
Old 05-29-2012, 08:40 AM   #21
CC69Rat
CC69Rat's Avatar
The first thing you want to find out is the width of your rear axle housing.
67-68 housing is more narrow than the later housing by .75" on either side. If you are looking at custom backspacing on your wheels you definitely want to know this before you order. Ex. 5" BS on one truck doesn't mean it will fit the same on another. .75" is huge when you're trying to tuck 20's + under your truck, bagged, etc. It can be a costly mistake.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-29-2012, 12:33 PM   #22
68Stepbed
68Stepbed's Avatar
Wow, this is an old thread! Since it's here, though, 10" wide wheels is max with stock bedsides. I'm running a 17x9.5 wheel with 275/55/17 tires with a 5.75" rear drop. I currently have a 71-72 rear(wider) and the wheels have a 5.5" bs and they rubbed the inner bedside, so I have to run 7/16" spacers and they still slightly rub in hard cornering. So basically, with a 71-72 rearend, 5" backspacing is ideal.
I'm going to have to change my rear gear soon. I'm thinking of building a narrower 67-70 rearend and ordering new 17x9.5 rear wheels with the correct backspacing, which I have determined should be 4.25".
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-29-2012, 04:11 PM   #23
Fitz
Some simple measurements that i used when adding tubs to my 67 stepside will help you work this out.
I started by removing the bump stops, then measured the distance from the wheel mounting surface to the frame and the distance from the frame to the inner flange on the fender. It also helps to know rhe distance from the bed si
Fitz is offline   Reply With Quote
Old 05-29-2012, 04:37 PM   #24
David67
David67's Avatar
lol 9 year old thread.....ehh why not. I'm running a similar setup to 68Stepbed. I'm running a 17x8 wheel also with 275/55/17 with a 6" rear drop on my stepside. I have the narrower '67 rear and my wheels have 4" bs with about an inch of clearance between rubber and inner bedside. Everything fits very nicely but I'm thinking about going with a wider wheel with the same bs as well as a wider tire because I could still come out a little more.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 05-29-2012, 05:00 PM   #25
barry h.
barry h.'s Avatar
oldtrucknut truck looks nice from rear,got any side view pics
barry h. is offline   Reply With Quote
