![]() Join Date: May 2010
Steering intermediate shaft removal
Probably a stupid question but how do I remove the intermediate shaft from the firewall?
Thank you
It only has original paint once |
Re: Steering intermediate shaft removal
What intermediate shaft? If you are talking the one piece from steering wheel to rag joint I think the whole column needs to come out. Its been awhile but some bolts on forward face of firewall and a couple holding the column up from inside?
I was hoping it was removable from the fire wall to the box. From your answer it sounds like it don't.
If it has been modified to a collapsible shaft maybe it can be separated.
#5 | |
![]() Join Date: May 2007
is there a squeeze clamp or clamp with a through bolt at the bottom of the column? if so it probably comes apart. if not, its likely a one piece shaft all the way to the steering wheel. I have seen guys cut the solid 1" bar and grind flats into it, making it a 1" double d, and use a double d adapter to a new collapsible shaft.
edit: or do it this way, just posted and is great stuff http://67-72chevytrucks.com/vboard/s...49&postcount=5
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 05-16-2015 at 09:30 PM. |
#7 | |
