05-16-2015, 05:43 PM | #1 |
Clutch fan
Is a clutch fan supposed to lock up, or does it only get harder to turn? I put in a new clutch and 7 blade fan to replace my old 4 blade clutch less fan. I also replaced the radiator and the water pump and the truck seems to run at it's normal temp for the most part, but it will spike to around the center of the gauge and return back again. The fan was the only part that I could think would possibly be an issue.
05-16-2015, 06:01 PM | #2 |
Re: Clutch fan
Check your coolant level? My gauge will behave in this manner if the level gets low. I'd imagine this is more of a coolant or thermostat issue more than a fan issue.
Does this happen during stop & go driving or highway? Regards, Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
05-16-2015, 06:17 PM | #3 |
Re: Clutch fan
I just replaced the coolant this morning, so it's possible I still have some air in the system.
It actually seems to act fine in stop and go traffic. It's when I'm running at a maintained speed that it acts up. Kind of opposite that I would expect. |
05-16-2015, 07:31 PM | #4 |
20' Daredevil (Ret)
Re: Clutch fan
May be some info here will help... http://www.aa1car.com/library/cooling_fan_clutch.htm
05-16-2015, 07:41 PM | #5 | |
Re: Clutch fan
05-16-2015, 09:07 PM | #6 |
Re: Clutch fan
could be your thermostat sticking. I just had same problem. I went with a 160 degree thermostat.
05-16-2015, 10:17 PM | #7 |
Re: Clutch fan
05-17-2015, 07:44 AM | #8 | |
Re: Clutch fan
I have seen thermostats fail open, twice. One of them was designed to fail open, unfortunately. I say unfortunately, because that version doesn't really fail open, instead it has a ratcheting mechanism that locks it open if the temperature reaches a certain level. If you find yourself pulling a mountain in the middle of summer your engine temp may go higher than "normal" and lock the thermostat open. Now you have to pull the thermostat for a one off event. But, I digress. If your thermostat is bad, there's no need to go with a cooler one. Just replace it with a like temperature part. Regards, Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. Last edited by MagmaJct; 05-17-2015 at 07:45 AM. Reason: Damn cat jumped on keyboard the exact moment I clicked "Submit"! |
05-17-2015, 09:52 AM | #9 |
Re: Clutch fan
if it is just getting hot to the center of the gauge setting that is a completely normal good operating range to b at nuttin to worry about not worth the effort to discuss
05-17-2015, 09:58 AM | #10 |
Re: Clutch fan
It's hard to tell with no numbers! In the past the gauge would only get to the first hash mark on the gauge. That was with a clutch less fan too. I believe things are running more efficiently now.
