Old 05-16-2015, 08:07 PM   #1
LeesTruk
vapor canister for LS swap
I want to hook up the vapor canister when I install the 5.3L in my '80 C10. The original many port canister is "dead", having puked most of its' fuel contaminated charcoal onto the radiator support. I'd like to use a later model 2 port canister and was wondering if I ran the canister purge line to the air filter box (stock filter box from '05 Tahoe) there would be enough of a vacuum draw to actually pull the fuel vapors into the intake. My PCM has been reflashed to eliminate the evaporative system, and my harness has no wiring capability for a purge valve. Any thoughts? Thanks
Lee
LeesTruk is offline   Reply With Quote
Old 05-16-2015, 08:34 PM   #2
clinebarger
Re: vapor canister for LS swap
That may work, I highly doubt it though. But drawing unmetered fuel vapor may cause fuel trim issues because the PCM doesn't know it's purging the tank.
clinebarger is offline   Reply With Quote
Old 05-18-2015, 12:27 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Why would you actually want to do this? (was it just a curiousity ?)
If your having vapor lock or fuel smell problems, they can be corrected with a breather or cap venting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-18-2015, 04:47 AM   #4
LeesTruk
No problems, just looking for a way to pull the fuel vapors from the canister and recycle them, that's all. If needs be, I'll just leave the purge line open at the canister. What's in the truck, now, is fouled and stinking of stale fuel and definitely needs to be replaced
Old 05-18-2015, 03:54 PM   #5
homemade87
All I did on mine was run the vent from the tank along side my fuel line and put a little vent like what comes on the rearends and bolted it to the back of the head . I get no fuel smell at all .
homemade87 is offline   Reply With Quote
