Old 05-16-2015, 09:32 PM   #1
OldChevy61
OldChevy61's Avatar
62 c/10 windshield /back glass
Any tips on getting the glass out in one piece. Never removed a windshield with the rubber around it. Also anybody have a line on new windshields for the 62. This one is use able,but rubber is rotten so has to come out anyway. Has a couple chips in it and bubbles around the edges. Just don't want to break it in case I do use it again.
OldChevy61 is offline   Reply With Quote
Old 05-16-2015, 09:38 PM   #2
duallyjams
duallyjams's Avatar
Re: 62 c/10 windshield /back glass
use a knife and cut out the rubber around the windshield, sometimes local glass shops carry windshield and some will replace it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-16-2015, 10:26 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
yep don't even try it another way, get a good sharp razor knife and cut away all the rubber until you see the whole edge of the glass. even then you have to be careful pushing it out ,if the corners grab or you push too hard in one spot you could start a crack.
rear window is much easier, pick a good hot day, so the rubber is a little more pliable, pull the bead lock out, and then at the seam slowly start working the rubber over the lip.
