05-16-2015, 10:38 PM | #1 |
clutch brake light issues
i think i know the answer but i want to make sure. is there anything in the clutch that is electronic? i am having a brake light issue. if i hold the brake pedal and compress the clutch pedal i blow a fuse right at the same spot every time. if i just press the brake pedal up and down without the clutch being pressed i have zero issues. i have looked for a exposed wire but dont see much. i will look better tomorrow
05-16-2015, 11:38 PM | #2 |
Re: clutch brake light issues
Nothing electrical that I'm aware of. I'm thinking bear wire that your not seeing. Unless somehow that has a neutral safety switch and its grounding out. lol Is it all stock?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-17-2015, 11:03 AM | #3 |
i agree i think the same thing. it has a kwik wiring kit stock 230 with 3 on the tree
05-17-2015, 04:04 PM | #4 |
got the short figured out. i didnt look at the opposite side of the steering column. looked on that side and had some exposed wires when the arm got to the same spot
