Old 05-17-2015, 11:03 AM   #1
Mathew21
Mathew21's Avatar
67-72 steering column shaft in 66' Column
Will a 67-72 Chevy truck steering column shaft in 66' Column and accept the 66' steering wheel?
Thanks, Matt
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 05-19-2015, 04:27 PM   #2
Mathew21
Mathew21's Avatar
Re: 67-72 steering column shaft in 66' Column
Anyone?
Old 05-19-2015, 06:32 PM   #3
vince1
I put a 67 shaft in a 66 column. In 68 they might have changed something. Does a 68 still have the spring at the bottom of the column?
vince1 is offline   Reply With Quote
Old 05-19-2015, 06:33 PM   #4
vince1
Yes the 66 wheel goes on a 67 shaft.
Old 05-19-2015, 08:20 PM   #5
Mathew21
Mathew21's Avatar
Thank you
Old 05-20-2015, 11:36 AM   #6
chevyrestoguy
chevyrestoguy's Avatar
I used a '68 shaft in a '65 column, worked great. I wanted to have the capability of having a collapsible steering shaft in a collision, so I used the intermediate shaft from my '79 donor truck. I cut off the factory encased u-joint from the intermediate and bought a 3/4 D-D to 36 spline u-joint from Flaming River. I had to shorten the shaft slightly in order for it to mate up with the steering box ('79 half-ton, power box). To shorten it, I drilled through the plastic shear rivets and then using a mini-sledge and a 4x4 block, I compressed the shaft to get it to the length I needed.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-20-2015, 12:51 PM   #7
Mathew21
Mathew21's Avatar
Great information. Thanks
