fuel tank filler neck
Anybody know how the fuel tank filler neck is attached to the tank on a 72. I bought a aftermarket tank an it only has a stub. I have my old tank out and the neck unbolted but it won't come off. I assume this means it is probably soldered on. I guess i could just cut the curved portion off and get it welded to the stub.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
Re: fuel tank filler neck
Soldered ...and a lot of people use the old one on their new tank because the repops arent right.
![]() Join Date: May 2006
X2 use a chisel to start the cut and then follow up with tin snips. mine had the two bolts and soldered, replacement tank is brazed on, I got it off by using a dremel cut off wheel, since the new tank never had gas in it, I wasn t worried about sparks blowing me to kingdom come
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
where are you cutting ?. Did you get the whole neck off including the flange. Then how did you attach the new one ?. I have a neck off of a old tank that I cut off with part of the tank still attached so that will be my donor.
#5 | |
just unsolder the oem neck from the tank metal that is left on the neck
I know all I had to do with my old tank was take a propane torch to it where it attaches to the tank and the solder melted off and the neck came right off. Had a radiator shop braze it to the new tank.
