What hood latches did squares all come with?
Picked up an amazing hood this weekend at a swap meet here in Washington, I'm thinking its 73-76ish it doesn't have the typical hood pin latch system on it like the hood on my 78 right now does. But I can't find anything in any of the catalogs. How many different latch systems did they have?
Matt |
Re: What hood latches did squares all come with?
I did a 73-74 grille swap on my 78 GMC, I bought the hood latch and striker plate on the hood as well thinking it was needed for the swap but my 78 hood latch and striker plate was the same as 73-74.
John 82 Chevy Silverado 350ci/TH350 ![]() |
#3 | |
Pin type = non locking hood hook type = locking hood The locking hood was a standard option starting in 77
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
The locking hood has the inside hood release cable. There will be a square loop bolted on the hood.
#5 | ||
Thanks guys! I guess the hood is newer than I had thought, It doesnt have the extra little body line on the front of the hood like my 78 currently does, its completely smooth which I thought came on the earlier models. But yes it has a square loop bolted to the hood.
Matt |
#6 | |
![]() Join Date: Jun 2009
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Collector of Projects
Bringing this back up. Is it possible to add the inside hood release cable setup to a 78.
78K & 79C Jimmys
Wondering too,I'm not sure,but removed what i could save from my 79K for my 78K.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I am pretty sure to do this you need the whole bolt on piece off the upper core support of an inside hood release truck
78K & 79C Jimmys
yes that appeared different and what holds the latch,down to the bottom of the rad
We need someone that has a 77-80 truck with cab mounted release cable to take some pictures to show the difference.
78K & 79C Jimmys
lol I have both, just no time
#13 |
