Old 05-17-2015, 09:49 PM   #1
NJ C10 Guy
Manual to Power brakes question
Quick question...
When swapping from manual to power brakes, do I need anything other than the following:
1. Pedal Assembly
2. Brake booster
3. Master cylinder
I'm thinking of changing out my setup now for vacuum assisted brakes. Will I run into needing any additional parts than the ones above? The brake lines and things of that sort that are already in place should be fine and bolt up to the MC, right?
Thanks in advance for the help!
NJ C10 Guy is offline   Reply With Quote
Old 05-18-2015, 12:02 AM   #2
MikeB
MikeB's Avatar
Re: Manual to Power brakes question
I suspect you'll need to fabricate or buy the lines that connect to the MC, because it will be moved farther forward by several inches.
So, the brake pedal setup is different? I guess the power version must have less mechanical leverage.
BTW, my 82 C10 has manual brakes and I am very pleased (almost shocked) at how well they work. Of course it's a relatively light, short wheelbase truck, and I've never hauled anything heavier than a few hundred pounds.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-18-2015, 08:05 AM   #3
77c10
77c10's Avatar
I did this swap a few years ago and only changed the booster, master cylinder and the lines going to the master cylinder from the proportioning vavle. I was able to re-use the original brake pedal with some modification.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 05-18-2015, 01:16 PM   #4
NJ C10 Guy
The manual brake pedal takes a different size pin for the pushrod than the power brake pedal. I really don't have a huge issue with the manual brakes, but power brakes are a nice add-on. I don't know if maybe I should just remove my clutch pedal and keep it as is. I think where the clutch MC goes into the cab through the firewall, there will be a hole left over if I remove it, and I really don't want to have to weld it up. I'm at a crossroads!
Old 05-18-2015, 03:44 PM   #5
1774btcrew
1774btcrew's Avatar
I got your email and will respond. I like power brakes and have had c10 trucks with both. If you have only had manual brakes on one of these you really don't know what you are missing. Manual brakes ARE fine in most situations. I just like have power brakes. It seems to me you are at a good point to upgrade to them.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 05-18-2015, 08:35 PM   #6
NJ C10 Guy
Ok, thanks. I am at a good point in my build, I just don't want extra expense or additional work I'm not too experienced with like welding closed a hole in the firewall left by the clutch MC.
Old 05-18-2015, 08:41 PM   #7
1774btcrew
1774btcrew's Avatar
The hole in the firewall doesn't have to be welded. Cut out a plate the shape of the mounting area of the clutch MC, drill two holes in it put a bead of silicone on the back and bolt it where the master cylinder bolted. I did something similar to this as my truck had a manual pedal assembly with the rod for the z bar going through the floor when I switch my truck to an auto trans. You can use nice button head allen bolts and it will look clean.
Old 05-18-2015, 08:58 PM   #8
NJ C10 Guy
That's a great idea. I made a deal with natedogg on the setup. I'll still have the hydraulic pedals, so keep in touch with me. I'm sure we'll be able to make something work.
Old 05-19-2015, 02:46 PM   #9
NJ C10 Guy
I removed the hydraulic clutch reservoir, MC and slave cylinder today. To take out the pedal assembly I assume I am going to have to drop or remove the steering column? I also pulled a wire from the main harness. Not sure where it went into. It's yellow. Good thing I have a diagram or I'd be in for some real fun...
Old 05-19-2015, 03:08 PM   #10
77c10
77c10's Avatar
Yep, you have to remove the column.
