![]() Join Date: Nov 2014
Front drums for 1970 k20 help
Hello I can not seem to find a place to buy some new front drums for my k20 truck it's a 1970 with 8 lugs and the shoes should be 12x2 any help would be great also I need to get rear drums for my eaton rear diff. Rear you have the bearings inside the axles. I prefer if there is a conversion so I don't have to pull axles every time. Thanks for the help guys.
Posted via Mobile Device |
Born Psycho
![]() Join Date: Feb 2001
Re: Front drums for 1970 k20 help
unless things have changed in the last few years, drums for 4x4s are nearly impossible to locate. my advice is swap the front to a later model with disc brakes and use a matching ratio 14 bolt in the rear. some newer 14 bolts have disc brakes if you want disc all-around.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Thanks for the help so far... I know it's tough. I don't have the extra cash for a convert to disk right now.
Post a wanted to buy thread in the parts forum, somebody may have a good used pair?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I had the same issue with my 1970 k20 gmc suburban. Even went as far as trying to get some made. Then a buddy at oreillys in tn found me a drum made for 1994-1999 dodge van! Fits perfectly with no machining or adapters! I will look for the part number and post it. They were about $50 each new
#6 | |
If you call your local O'Reilly store and ask for the rear drum from a 1994-99 dodge 3/4 or 1 ton van you will have front rotors again!
When I said Rotors I meant to say brakes sorry.
Sorry this took so long. Replacement for front brake drum on 1970 K20 through O'Reilly's is Part# 9625DGS $46.99 each currently. Good Luck!
