Old 05-18-2015, 04:52 PM   #1
Crazy Rusty
Crazy Rusty's Avatar
Question Temporary Floor Sealing
Any ideas for temporarily fixing rust holes in the floor boards? I'm going to slap some POR15 on but won't be able to get to welding in new pieces until next year. I was thinking about drilling holes and putting in some rubber stoppers...
Any one have ideas? I would leave it alone but up here in the NW we'll be getting rain from Sept-May and I've already found it wet under the carpet since I got it a week ago just from driving.
Crazy Rusty is offline   Reply With Quote
Old 05-18-2015, 06:14 PM   #2
joe dirt
joe dirt's Avatar
Re: Temporary Floor Sealing
maybe just some sheetmetal and caulking and screws for now
joe dirt is offline   Reply With Quote
Old 05-18-2015, 06:46 PM   #3
63burban
Chevy addict
Screws and sheet metal. don't put the POR on until you are completely finished, it's almost impossible to get off once it's dried.
63burban is offline   Reply With Quote
Old 05-18-2015, 07:11 PM   #4
Jcox68rt
Or use the por15 with their fiberglass matting that you paint right over the with Por15... I've used it on very minor rust holes before and it's hard as steel once dried. I wouldn't use over quarter sized holes or bigger though..just an idea. If the holes are small and minor this could be a near permanent fix.
Jcox68rt is offline   Reply With Quote
Old 05-18-2015, 11:10 PM   #5
rcnutt
rcnutt's Avatar
I second this....works great
rcnutt is offline   Reply With Quote
Old 05-18-2015, 11:23 PM   #6
OldGMJon
OldGMJon's Avatar
Question Re: Temporary Floor Sealing
could you explain that por 15 and fiberglass matt routine again with a little more detail?
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 05-19-2015, 08:54 AM   #7
Improbcat
Improbcat's Avatar
You don't need to use POR-specific fiberglass mat, any of the chopped-strand type fiberglass mat will work.
Do all your rust grinding & surface prep, then trim a piece of the mat to cover the holes and overlap onto good metal. Lay down a coat of POR on both sides of the metal as usual, then lay the mat on a plastic covered surface and brush it with POR on both sides, forcing the POR into the weave. Lay this over the still-wet POR on the metal, and use a POR covered brush to force any air bubbles out and the mat hard against the metal. Wait for the POR to dry and put another coat of POR on both sides to seal the mat & metal together.
Be aware that you are going to have to cut out the entire POR & mat section and weld in new metal as there is no way to remove this fix from the metal for welding.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 05-19-2015, 10:16 AM   #8
dtkarst
I used regular fiberglass matting on my floors by the kick panels on my k20. Then sprayed some sound deadening undercoating over it before layig my carpet it. Worked great
dtkarst is offline   Reply With Quote
Old 05-19-2015, 12:49 PM   #9
OldGMJon
OldGMJon's Avatar
Thanks for the details...I was under the assumption that POR 15 worked best on rusty portions because it reacted with the rust. In your explanation you grind the rust off. Do you lose any of that reaction by doing so?
Projects:
65' Chevy Panel swb
Parts:
Old 05-19-2015, 12:55 PM   #10
Jcox68rt
You just need to get the heavy scales stuff off and get it prepped according to por15 directions so it will adhere well.
Old 05-19-2015, 12:58 PM   #11
OldGMJon
OldGMJon's Avatar
Wink Re: Temporary Floor Sealing
OK I see what you mean now. Thanks for the info...
Projects:
65' Chevy Panel swb
Parts:
Old 05-19-2015, 06:48 PM   #12
Crazy Rusty
Thumbs up Re: Temporary Floor Sealing
Thanks everyone. I think I'm going to use some POR15 on the stuff I'll be cutting out anyway and then probably the caulking/sheetmetal. A little worried I might overdue it if I go the fiberglass route
Old 05-19-2015, 07:55 PM   #13
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
This almost sounds like a good permanent fix for the floor. I mean, if you clean the floors and you only have small holes why couldn't it last you the rest of your life?
66 C20 Service Truck:
Old 05-20-2015, 03:20 AM   #14
Jcox68rt
All depends. How bad the rust is to start with, where you live (climate), & how the truck/car will be used once done. I did this to an old survivor Plymouth Valiant I had, I didn't drive it or park it in the rain once I got and I gave the pin hole floorboards this treatment and it lasted for many years, put new carpet in it earlier this year to sell it and floors and trunk looked like I had just done them. I also did this to the pinhole trunk floor in my 68 Charger RT show car about back in 2001. I haven't lifted the carpet in it since...might have to go investigate to see what it looks like now...probably looks like it was just done, It hasn't been in the rain or washed (just wiped down) since.
