05-18-2015, 04:55 PM | #1 |
'63 3sp Saginaw to TH350 Swap
I'm sure this topic has been beaten to death but I've been unable to find a parts list or "directions" for making this swap. Obviously a trans, shifter, linkage etc... is necessary but can anyone tell me what else may be required to perform this swap? I'm primarily concerned with materials required under the truck. Thanks everyone in advance.
05-18-2015, 05:09 PM | #2 |
But Found Her 25yrs Later!
Re: '63 3sp Saginaw to TH350 Swap
Radiator with trans cooler. Or a separate cooler.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-18-2015, 05:28 PM | #3 |
I did find these similar threads :
http://67-72chevytrucks.com/vboard/s...d.php?t=587314 http://67-72chevytrucks.com/vboard/s...d.php?t=265254
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 05-18-2015 at 06:08 PM. |
05-18-2015, 05:56 PM | #4 |
Moderator
The cross-member under your current 3 speed (at about the firewall) will go away. The cross-member for the tail-shaft of the TH350 will have to be installed.
The cross-member currently in place where the emergency/parking brake mechanisms are will most probably have to be removed. This may help but remember it's a 62 not a 63: http://67-72chevytrucks.com/vboard/s...d.php?t=626071 and http://67-72chevytrucks.com/vboard/s...light=sbc+1960
05-18-2015, 06:04 PM | #5 |
As mentioned in the thread I linked; you'll need a starter that can mount to your block.
05-19-2015, 07:12 AM | #6 |
Thanks for the responses, guys!!! I suppose my concern in a cross member that is required to support the TH350. Does anyone make one for the '63 or is it something that I have to fabricate? I know that there are those on the board that fabricate plates for power steering boxes and brake master cylinders...
05-19-2015, 08:41 AM | #7 |
Moderator
Classic Performance Products Inc (CPP)
Ebay
05-22-2015, 07:57 AM | #8 |
Thanks Master Chief!!! I've ordered that crossmember!! So far, I've got the crossmember, starter, trans cooler, and floor shifter....can anyone think of anything else???
Thanks in advance everyone! |
