05-18-2015, 08:09 PM | #1 |
Automatic?
I was wondering if any of the 1960's models trucks came as automatics?
:ito ::gm c2: |
05-18-2015, 08:13 PM | #2 |
Re: Automatic?
Yes All years in the 60's offered the automatic transmission.
05-18-2015, 08:41 PM | #3 |
Re: Automatic?
60-66 offered power glide, 66 you could get a turbo400
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
05-18-2015, 08:55 PM | #4 |
Re: Automatic?
60-62 GMC's offered Hydra-matic's. 63-66 GMC's used powerglides and in 66 they also offered turbo hydra-matics.
05-18-2015, 09:27 PM | #5 |
Re: Automatic?
Would you recommend keeping the 305 V6 motor thats in the truck?
05-18-2015, 09:35 PM | #6 |
Re: Automatic?
If the 305 V6 runs good HECK YEAH I WOULD!!! These engines are great engines and anyone who says other wise is NUTS. If it has good compression and runs good then I'd keep it, BUT what Really matters is what you want out of the truck...mileage? Put an LS in there....Great torque and power...Leave the 305 in there. People dog about the 305 V6 and need to stop. I own one and am really happy with it..great engine...188,000 on it and 120 pounds in all cylinders(125 brand new). Ain't an RPM engine but will pull a heavy load without a sweat. Only reason GM quite making them was because they were to good.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-18-2015, 09:37 PM | #7 | |
Re: Automatic?
05-18-2015, 09:45 PM | #8 |
Re: Automatic?
Depends on if it runs good and how you are going to use the truck. If you are going to use it as a truck it is a good motor. If you are wanting to put an automatic in it you are going to need an adapter plate. Check out this site, it has a lot of info about the V6's http://6066gmcguy.com/index.php
05-18-2015, 09:59 PM | #9 |
Re: Automatic?
Carb kits are available at Auto Zone for about $35 I think. Ya may consider the 500 Holley 2 barrel swap. Heard alot of good things about it and will be doing it on my 305E.
05-19-2015, 09:19 PM | #10 |
Re: Automatic?
I have the 500 holley but the biggest improvement was the dual exhaust really woke up the 305.Plus most people have no clue what the engine is.
