Member #1049
Wire terminal housings
5 ignition switch housings with good tabs (these are quite often broken and one has one slot slightly melted from a hot wire)
6 head light switch housings 5 battery to power wire terminals 6 4 connector housings, some are for non AC heater and the others are for the rear light harness (not sure which is which) 5 brake light switch housing with good tabs 6 backup light switch housings 3 neutral safety switch housings 2 wiper switch housings 2 turn signal switch connector housings $30.00 for all shipped (CONUS only) |
![]() Join Date: Dec 2009
Re: Wire terminal housings
I will take them please!
Payment sent!
Member #1049
SOLD... Thank you!!
