Old 05-18-2015, 09:16 PM   #1
65standard
65standard's Avatar
A common issue with patch panels (fix)
As with some patch panels, there are some fitment issue that are expected. Here is a left side cab corner patch made in the orient that just is a little off. I decided to correct this.
Here the door gap with the cab corner is folded over a little off.
To correct this, I marked where I want the folded corner to be with blue tape.
Then I used a body hammer and dolly that matched the folded edge. I held the dolly back from the corner and at my tape line. Then hammered the folded over corner until I moved it in with the tape line. I worked the edge along the tape line until I corrected the edge. Took me about 60 seconds.
The new edge.
Another view. Here you can see where I moved the corner 3/16 inward to nothing.
Then I welded the cab corner in and metal finished it.
Finally, I primered it, body caulked the seam between the rocker and cab corner, and painted it. All within three hours. Again there is zero bondo used or needed if you take the time to fit the panel perfectly and metal finish the weld. By this I mean carefully grind down the weld without heating it up too much, get it as close to the parent metal with a grinder, then correct any low or high spots with a hammer and dolly, go back and file the weld down more until to even it up with the parent metal. Then block sand the area to see if there are any small lows or highs, correct and repeat until perfect.
The end result is a perfect repair that is undetectable.
The after view.
The before view.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 05-18-2015, 09:37 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: A common issue with patch panels (fix)
Very nice, good job.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-18-2015, 09:50 PM   #3
JHT67
JHT67's Avatar
Your on a roll with this truck. I have always loved metal shaping, and and you're showing that sometimes all it takes are some littles tweaks to make things right. Just fun to watch.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 05-18-2015, 09:53 PM   #4
JHT67
JHT67's Avatar
Now did you just hold the corner and dolly in your hand?
Old 05-18-2015, 09:56 PM   #5
Ohio mike
Pretty impressive! Thanks for the pics and tips.
Ohio mike is offline   Reply With Quote
Old 05-18-2015, 09:59 PM   #6
65standard
65standard's Avatar
Yes, I just sat down with the patch panel on my lap and held the dolly and panel in one hand and the hammer in my other hand. Took one minute to correct about 5" of that edge.
Old 05-18-2015, 10:42 PM   #7
truckster
truckster's Avatar
It's nice to have skills and it's even nicer when people share their skills.
Thanks!
truckster is offline   Reply With Quote
Old 05-18-2015, 10:44 PM   #8
WarMonger
WarMonger's Avatar
man, do you some serious fab skills.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 05-18-2015, 10:49 PM   #9
In The Ten Ring
How do I hire this man?
In The Ten Ring is offline   Reply With Quote
Old 05-19-2015, 02:04 AM   #10
swamp rat
swamp rat's Avatar
Thank you sir! I agree with the previous poster, how do i hire you! can you work on my truck telepathicly? LOL!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
