350 Timing?
I have a '71 c10 lb. Recently replaced motor with a crate 350. After a couple thousand miles had a mild cam installed. I didn't get the performance boost I wanted. My question: What is standard timing, and given the cam, what would be a reasonable amount of advance? People I've asked have suggested I take it up to 30 degrees after tdc. I'm pretty sure that's way too extreme.
Another question relates to replacing stock exhaust manifolds with headers. Is there a real world advantage to this? I'm trying to get the most I can out of it without boring, new heads, etc. Thanks for your help. |
#2 | |
Re: 350 Timing?
Most (but not all) headers are "tuned" (by changing the length of each tube) to get the best flow rates at a design RPM. Expect 5-8 percent increase in power which, for a crate 350 translates into about 15 horsepower. Probably not worth the investment or the aggravation they will give you UNLESS you are drag racing that truck. Getting the timing correct for your cam would give much more. |
Re: 350 Timing?
Just installed a 350 crate in mine and I set it at 10* BTDC, I'm passed trying to race anyone and just wanted a good running motor...
Re: 350 Timing?
With a mild cam you can run anywhere from 10* BTDC to 18* BTDC. You just listen for any pinging and back it off if you have to much.
I'm currently running 18* BTDC on my truck. |
