Chemist under the hood...
Air Filter-Quadrajet 283
Probably a dumb post but I did honestly search and couldn't see others with this problem.
My '67 283 has a 4 barrel quadrajet and an air cleaner that fits the 4MV carb. There was a FRAM CA326 in it a 6 years ago when I bought it. I found at a swap meet a Motomaster MCA 326 which fits fine (although slightly looser)-I'm Canadian remember. I thought I would order a replacement from Rock Auto and I got a Wix 42091. The Wix doesn't fit as the ID is only 8.59" instead of 9.8 inches for the FRAM CA326. The Wix cross references to a Fram CA176. I'm thinking I have the wrong air cleaner on this 283. I know the stock was a 2-bbl with an oil bath air cleaner but I thought all quadrajet carbs had the same air filter size. Just wondered if anyone else had this issue and what part they are using. Thanks
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Re: Air Filter-Quadrajet 283
You definitly have the wrong air cleaner because 283's never had quadrajets. However, just get another fram filter at Canuck tire!
They all have the same size mounting hole that fits the carb but there are many variations in the filters & cartriges. Get the cart. that crosses with the cart. that was in it. Make sure the filter housing clears all the throttle & choke linkages. Some have to have an extension.
#4 | |
This one is simple . Your ca326 crosses to a 42098 wix , If you called your local parts guy in St. Catharines , he would easily tell you that , pull the filter off his shelf , pull over when you have a flat on hwy 3 , and offer you some good original wheels.... let's see mail order rock auto do that! Seriously , there are a bunch of original housings that fit a q-jet , that filter you need is easy to get anywhere , ... I just happen to be the parts guy in st. Catharines ......
#6 | |
Tags |
air filter |
