05-19-2015, 03:56 PM | #1 |
72 brake pedal bracket.....????
Just a quick question.... Does anyone know if the brake pedal assembly from the 73-up trucks work in the 67-72?? Having trouble finding a bracket and pedal for an auto trans 72 truck..
Posted via Mobile Device |
05-19-2015, 04:19 PM | #2 |
All about them K’s
Re: 72 brake pedal bracket.....????
Not sure on the 73 up stuff but the 67-72 auto and manual brackets and pedals are the same the clutch just slides into the brake pedal bracket. Fyi
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
05-19-2015, 04:23 PM | #3 |
Isn't the brake pedal arm and pad different then the manual? More toward the left and a bigger pad?
05-19-2015, 04:56 PM | #4 |
member #16
No, same pedal for all 67-72's. std or auto.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 05-19-2015 at 07:23 PM. |
05-19-2015, 08:27 PM | #5 |
05-19-2015, 08:37 PM | #6 |
The bigger pedal for autos happened after our body style.There are somr threads on here about putting a big pedal on but it is a cut and splice weld type thing.
I plan to cut off the auto pedals from some trucks I've junked either the 99and up or the 88-98 style I have tons of both. Jim |
