Old 05-19-2015, 11:32 PM   #1
crazychevyc10
how to remove bottom spindle? HELP!
hey guys...need help
i'm changing into drop spindles and i'm stuck with one last step...i can't seem to pop out the bottom part of the spindle. any suggestions?
thanks!
crazychevyc10 is offline   Reply With Quote
Old 05-19-2015, 11:34 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: how to remove bottom spindle? HELP!
BFH... seriously... a BFH.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-19-2015, 11:56 PM   #3
Custom/Ten
Custom/Ten's Avatar
OrName:  image.jpg
Custom/Ten is offline   Reply With Quote
Old 05-20-2015, 06:56 AM   #4
kingstrider
kingstrider's Avatar
This reminds me of the time I was rebuilding the front suspension on my old Mustang. I had been at it for some time giving it hell with a hammer and a pickle fork with no luck. My dad came over and must have had a tough day at work because he took one or two good whacks with the hammer and broke the parts free. He said you just gotta show the car who the boss is. Since then I have come to realize the value of a BFH and good old American muscle.
kingstrider is offline   Reply With Quote
Old 05-20-2015, 08:07 AM   #5
67 chevelle
67 chevelle's Avatar
Get someone who has done it before to help you ,,, it can be a very dangerous operation
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-20-2015, 08:13 AM   #6
spidermn
spidermn's Avatar
You are going to need a ball joint fork and a BFH! Just like the guy above said. You might want to put the a jack under the spring on the A arm and bolt the top side in and taking the bottom crown nut off, the weight plus a little help from the tools above with get it loose. Just be careful releasing the tension from the spring. Do this and it will come right off.
Go BIG or GO home!!
1970 Custom Chevy C10 / 350 bored .30 over / 5.5/7 drop on 20" boss 338
spidermn is offline   Reply With Quote
Old 05-20-2015, 11:34 AM   #7
leddzepp
Moderator
leddzepp's Avatar
All you need to do is loosen the castle nut, leaving enough threads so it stays on. BFH and smack the side of the spindle. A few whacks and it will "pop" and be loosened. Use a floor jack to lower the control arm carefully after you remove the castle nut completely. For safety hook a chain around the coil spring so it doesn't fly out. They usually just fall out but it's nice to have extra safety.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-20-2015, 11:46 AM   #8
Aruba1
Exactly right! I spent HOURS beating on mine with a pickle fork and a large hammer with no results. My uncle who is a mechanic came by and after 30 seconds he got it loose. He said the right hit and right attitude will get it done. He wasn't kidding.
Aruba1 is offline   Reply With Quote
Old 05-20-2015, 12:05 PM   #9
Custom/Ten
Custom/Ten's Avatar
Unhappy Re: how to remove bottom spindle? HELP!
My feelings are a little hurt that no one liked my idea. O well, maybe I will feel better after a cup of coffee.Name:  image.jpg
Old 05-20-2015, 12:51 PM   #10
michael bustamante
michael bustamante's Avatar
same here. i beat the hell out of mine with bfh and a pipe extension it took about about 20 minutes of beating per side after i used the pickle fork
1967custom
michael bustamante is offline   Reply With Quote
Old 05-20-2015, 12:55 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by Custom/Ten View Post
I have that same tool from harbor freight. It works great for tie rod ends, far better then a pickle fork IMO
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-20-2015, 03:44 PM   #12
Hart_Rod
Hart_Rod's Avatar
This is what I use:
http://scandc.com/new/node/183
Hart_Rod is offline   Reply With Quote
Old 05-20-2015, 05:39 PM   #13
WarMonger
WarMonger's Avatar
Gary
X2 for sure. Big Big hammer
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 05-20-2015, 06:54 PM   #14
franken
The spring tension is relieved and the LCA is free to move, right? You may want to jam a pickle fork in there with the BFH, then bash the spindle next to the tapered part of the BJ. It helps a bit to have something pushing things apart when you hit it.
franken is offline   Reply With Quote
Old 05-20-2015, 09:22 PM   #15
GASoline71
GASoline71's Avatar
No pickle fork, no fancy bars, no other tools. Just hit it HARD with a BFH. Same for tie rod ends in spindles as well.
Gary
Old 05-20-2015, 10:25 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by leddzepp View Post
all you need to do is loosen the castle nut, leaving enough threads so it stays on. Bfh and smack the side of the spindle. A few whacks and it will "pop" and be loosened. Use a floor jack to lower the control arm carefully after you remove the castle nut completely. For safety hook a chain around the coil spring so it doesn't fly out. They usually just fall out but it's nice to have extra safety.
x2
WIDESIDE72 is offline   Reply With Quote
Old 05-20-2015, 11:04 PM   #17
H20cooled
I've taken lots of ball joints off and the easiest and the safest way is with a ball joint separator. They are only $20 at HF and you can find 20% coupons online. I have beat the heck out of mine and never had an issue, its one of the best tools for suspension work.
H20cooled is offline   Reply With Quote
Old 05-20-2015, 11:46 PM   #18
crazychevyc10
i just bought one today and i don't know about yours but i can't find a good place to place the dam thing. i feel like the separator is too small!
i hit the dam thing all over with a big hammer and also got the pickle fork to get all the way in and its still not popping!!!!
i have to stop now cause its dark here and don't wanna piss off my neighbors. i hate this dam thing. i sprayed the heck out of it with lubricant too
ahhhh!!!! still no luck!
Old 05-21-2015, 01:31 AM   #19
leddzepp
Moderator
leddzepp's Avatar
Bingo. The harbor freight tool I referenced will not fit the lower ball joint/control arm. Iirc, it will work on the upper if you flip the brackets. It is good for separating the tie rod ends at the center link. I used it at some point in my build thread years ago. For all else, in reality, you only need a BFH as Gary posted above. In my experience a picklefork just tears up your grease boots. Loosening all castle nuts and letting the compressed spring pop everything works. Don't be afraid to hit the spindle HARD, you won't damage it. Just wait until daylight so the neighbors don't complain
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-21-2015, 07:15 AM   #20
68C15
blood type; Retumbo
68C15's Avatar
leave upper attached to create upward pull on spindle. Loosen lower nut. Place jack under lower arm. hit spindle REAL hard with hammer by ball joint
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-21-2015, 08:49 AM   #21
H20cooled
It works but you have to open up the mouth of it big enough to fit the lower ball joint. I just used a sanding disc to open up the mouth of it now it fits everything I work on. I figured for the price if I mess it up its not a big deal.
Rich
