Old 09-02-2003, 03:21 PM   #1
PHOENIX
Best Rubber Valve COver Gasket?
I plan to change the valve cover gaskets soon.
I currently have a set of the orange Fel-pro gaskets on there ($20-30).
They have the black plastic insert in the center.
They also have the little ridges along the gasket.
My current covers are most likely bent and causing the leak.
I have an extra set of these gaskets, but was thinking of trying something else. I do not like the ridges in the gasket. I would prefer a consistant solid shape, like stock cork gaskets. Does anyone make a rubber valve cover gasket like that?
Price is not an issue. I am tired of the leaks. Plus I have some nice cast covers that should distort less and give a better seal.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 09-02-2003, 05:58 PM   #2
apstguy
LED King
apstguy's Avatar
Are the orange ones the PermaDryPlus material? (Same stuff as used in the one piece oil pan gasket) Those work awesome for the oil pan.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 09-02-2003, 06:17 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
I have never used rubber valve cover gaskets on the 85. I use Mr. Gasket's Ultra Seal's. They have never leaked. These are a composition cork gasket. I glue them to the valve cover. This way, I can remove the cover and not destroy them. I've had the covers off several times and never replaced the gaskets. No leaks as of yet. I think they would work well for you since you will need to be removing the covers on a regular basis adjusting the valves.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-02-2003, 06:19 PM   #4
71-longbed
Its Magically Delicious
71-longbed's Avatar
i have cork on mine as well ...removed them many times... the po had rubber and they leaked
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 09-02-2003, 06:40 PM   #5
1FaastC10
1FaastC10's Avatar
i've always used cork on SBC valve cover gaskets, and never used a drop of sealant. havent had any leak yet. one set is still going strong 7 years and 50,000mi later (guy i wiork with owns my first truck, and he has never touched the motor, i was the last one to do anything to it)
1FaastC10 is offline   Reply With Quote
