Old 05-21-2015, 01:18 PM   #1
gramps77
serpentine with smog pump AND Sanden compressor
Im looking at swapping my 77 over to serpentine but need the smog pump still and would like a Sanden compressor. Ive searched here and haven't found anything regarding Sanden adapting and I THINK an idler pulley can be swapped out easily for the smog pump.
Any help would be appreciated.
gramps77 is offline   Reply With Quote
Old 05-21-2015, 02:05 PM   #2
gramps77
Re: serpentine with smog pump AND Sanden compressor
I answered part of my question by finally finding this.
http://www.vintageair.com/Instructions2013/901805.pdf
an easy adapter kit for the 508 compressor
Old 05-21-2015, 11:35 PM   #3
520-k5
520-k5's Avatar
You can run the smog pump, use the smog pump delete pulley or just run without it all together depending on what serpentine bracket set you have. Yes vintage air sells a sander bracket kit and I believe holley has a kit as well? Here's my old 74 k5 with a serpentine setup off a. 89 camaro I just ran straight off the ac comp you the crank pulley
520-k5 is offline   Reply With Quote
Old 05-21-2015, 11:40 PM   #4
520-k5
520-k5's Avatar
Here's the mock up on the stand. I had the smog pump on it here thinking I needed to run it as a dummy. Turns out the bearing was bad and had to pull it Off. I researched google and ended up rerouting the same belt
Old 05-22-2015, 02:32 PM   #5
gramps77
thanks a lot 520.
I planned to buy a GM new serpentine kit withOUT the AC compressor then just get their Sanden adapter to install a Vintage Air kit.
your pics help greatly
Old 05-22-2015, 02:41 PM   #6
520-k5
520-k5's Avatar
I wouldn't waist the money on a new kit. I had less than 400 in my used junkyard kit and that was with new water pump,belt,fan clutch,p/s pump. Only the alt and ac compressor were used. You can buy them from the u pull it yards for around 125 bucks complete
