Old 05-21-2015, 01:53 PM   #1
pvienneau
pvienneau's Avatar
10 bolt 70-81 camaro posi rear end with 273 gears
Hello all, just found a 10 bolt 70-81 camaro posi rear end with 273 gears in my hometown. What are the odds someone knows whether this fits in a 1949 Chevy 3100 with a 235 and a SM420? The frame is original, straight, and on the money.
Pat
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 05-21-2015, 02:36 PM   #2
fine69
fine69's Avatar
Re: 10 bolt 70-81 camaro posi rear end with 273 gears
Define fit? You can make it work. But i doubt that the springs are the same with for the rearend. Get out a tape measure and check it out.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 05-21-2015, 03:12 PM   #3
bowt1ed
Works great on a TF, but I believe a bit too wide for an AD (unless narrowed).
bowt1ed is offline   Reply With Quote
Old 05-21-2015, 03:32 PM   #4
Lokin4AReason
Lokin4AReason's Avatar
that would be a bit to wide ... sell that and get a 8" or a 9"
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 05-21-2015, 10:06 PM   #5
xaircav
xaircav's Avatar
I put one from a '76 into my '53 using CPP 4754RCK kit. It adapts the stock springs to the rear and centers the tires in the wheel well. The Camaro axle is just the right width for an AD truck and has been done many times. I have a 2.73 ratio also and with 255-70 X 15 tires 70 MPH is 2200 RPM. Good score with the posi. Wish I had one. It won't work with the torque tube driveline however.
xaircav is offline   Reply With Quote
Old 05-22-2015, 06:53 AM   #6
pvienneau
pvienneau's Avatar
Good news from you guys. Thanks. The guy sold it. I am going to look for a s10 4x4 rear end.
Pat
