Old 05-21-2015, 02:49 PM   #1
1970pelle
1970pelle's Avatar
Is there any such thing as a right side A/C bracket
I'm changing things around during my crate engine install. Since I'm also going to headers, I want to move away from exhaust mounted brackets.
My 86 C20 has a R4 A/C compressor which I'm planning on giving it the big toss, and go to a Sanden R134A Compressor. I have been looking over all the options of custom and other year engine accessories. I don't understand way it seams everyone who has designed a bracket. Puts the said part up on top of the engine, rather than hid it. Its not like most older Chevys lacked room under the hood. I would like to move the A/C compressor to the right(passenger)side of the engine compartment. Under the Alt, nice and neat.
If anyone knows of such animal, please pull my chain. Thank you Ken the aluminum polishing fool. Did you know that P/S lines will look like chrome with just a little elbow grease.
KA
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 05-21-2015, 03:57 PM   #2
geezer#99
geezer#99's Avatar
Re: Is there any such thing as a right side A/C bracket
Alan Grove makes a low mount but it compromises the fuel pump. Workable or adaptable.
http://www.alangrovecomponents.com/S..._Long_Pump.htm
geezer#99 is online now   Reply With Quote
Old 05-21-2015, 04:42 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
That low mount looks interesting but I'd like to see one mounted on a square. It looks like it'd get into the frame rail. Are you using one?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-21-2015, 06:55 PM   #4
1970pelle
1970pelle's Avatar
I have looked at the one already, it will be a close fit with the frame rail. Plus I don't want to mess with a electric fuel pump and regulator.
I may end up adapting something, I already have the Sanden compressor from past projects. And making new A/C lines isn't a issue. I'm going to go with a 134A Style condenser also while apart.
― Ronald Reagan
Old 05-21-2015, 07:09 PM   #5
xole
xole's Avatar
Here is an Alan Groves mounted in the stock location but it mounts to the front of the block. I think I also had to use the one for the ps steering pump to lower it a little to make it all fit.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 05-22-2015, 02:39 PM   #6
1970pelle
1970pelle's Avatar
Great pic's. Very help full. PM sent.
― Ronald Reagan
Old 05-22-2015, 04:20 PM   #7
wpotter
wpotter's Avatar
You can relocate the alternator to drivers side above the power steering and install the Sanden 508 compressor on the passenger side. www.vintageair.com sells the brackets to do so. What style headers are you going to run? Some headers have the first tube run straight back to the firewall blocking the header bolts. This will interfere with many aftermarket brackets that use the first and third exhaust bolts to mount. Try to get headers where the first tube goes down and meets the rest.
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
