Old 05-21-2015, 03:40 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
1970 4x4 parking brake cable
I was finishing my brakes and all I have left is the parking brake cables, I went to attach the one that goes from the lever to the cable, and the one I bought from lmc is too short. When I ordered it the diagram had no separate models available just the 2wd, I assumed theyd be the same but theyre totally different. Any idea where I could get the proper one? Anyone have any part numbers? I ordered number 3 front cable and its wrong..
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 05-21-2015, 04:17 PM   #2
weeniewawa
Re: 1970 4x4 parking brake cable
inlinetube.com can make whatever you need. if you call them make sure you only talk to the guy who does the duplication of the cables, he seems to be the only guy at the company with any smarts. the techs who answer the phones for tech support are as dumb as a bag of hammers as well as the people who take phone orders.
is this a Chevy or GMC?
it makes a difference as I found out. most places know chevys but think GMC's are the same but the parking brake systems (and most other things before 1970+ something) are completely different at least on my 64
weeniewawa is offline   Reply With Quote
Old 05-21-2015, 04:52 PM   #3
leftybass209
leftybass209's Avatar
I'm not doubting you that it's shorter, but how is it shorter? The body still mounts on the same bushings, the same distance from the hole in the frame where that cable locks into. Unless the passenger side rod that slides through the frame to provide support to the other cable is different, I don't understand how it can be shorter. I do understand that the cable that runs a U pattern and connects to the rear brakes would obviously be longer. I'm just not a 4wd guy so I'm trying to pick up some tips.
leftybass209 is offline   Reply With Quote
Old 05-21-2015, 07:12 PM   #4
sboris
sboris's Avatar
In short, the center cable has to clear more stuff, transfer case, so the center is shorter and the one coming from the cab mounts further down the frame. Requiring it to be longer.
And yes, I second inline tube. Had no issues though with the order.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
