Old 05-21-2015, 07:19 PM   #1
FarmerSid
FarmerSid's Avatar
95 Roadmaster 4L60E matted to 07 L33 5.3
Found a L33 5.3 for my 51 truck build. I have a complete and running 1995 Buick Roadmaster with an LT1 for parts. My original plan was to use the LT1 for my build but I think I want to go LS.
Can I use the Buick trans with the L33?
What other things should I get from the wrecker yard to use the L33?
Cheers!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 05-21-2015, 07:26 PM   #2
jayoldschool
Moderator
Re: 95 Roadmaster 4L60E matted to 07 L33 5.3
Not easily. The 4L60E behind the LT1 has the old-style bellhousing on it. Try and grab the trans that goes with the LS.
jayoldschool is offline   Reply With Quote
Old 05-21-2015, 07:40 PM   #3
FarmerSid
FarmerSid's Avatar
Thanks Jay. Just the trans or anything else? The trans is from an 2wd iron block 5.3. Not the L33 engine.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-22-2015, 09:52 AM   #4
aknovaman
Only bell housing difference is you have to leave the bolt out at the 1 o'clock position.
You will need to get correct flywheel and program PCM for non-pwm operation.
It will bolt right up same as a th350 and 400.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 05-22-2015, 07:57 PM   #5
clinebarger
LT1 4L60E's in '95 have a PWM TCC solenoid, They also have a PWM 3-2 shift solenoid vs a "on/off" 3-2 on '96 & up models.
'95 is the ONLY year to use this arrangement, And ONLY in LT1 cars. '95 trucks were still Non-PWM.
I strongly advise against using a '95 PWM 4L60E behind any LS engine.
clinebarger is offline   Reply With Quote
Old 05-23-2015, 07:14 AM   #6
FarmerSid
FarmerSid's Avatar
Thanks for the info guy's. So is there any particular year etc 2wd tranny I should be looking for? What other parts should I get with it? The L33 5.3 is out of a 2006 4wd truck.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-23-2015, 08:29 AM   #7
aknovaman
Use the correct flex plate for your engine. You can use 1999-up 4L60e with ease.
The older 60e can be used but I don't recommend it because of all the above mentioned issues.
FMCDH GBU and GBA
