Old 05-21-2015, 09:25 PM   #1
crazyjim
crazyjim's Avatar
Need help on door ajestment
Rebuilt the hinges but cant get it come up enough to line up the body line
crazyjim is offline   Reply With Quote
Old 05-22-2015, 02:16 PM   #2
OrrieG
OrrieG's Avatar
Re: Need help on door ajestment
Bolts from hinge to cab control vertical, original hinges?? Did you replace the hinge pocket metal on the cab?? Original door?? Does the latch line up, you need to have the latch in place because it affects the back vertical alignment. PIcs of the hinges would help diagnose too.
OrrieG is offline   Reply With Quote
Old 05-22-2015, 03:59 PM   #3
mr48chev
mr48chev's Avatar
I could probably help you fix it easier than I can tell you how to do it.
What I would do is loosen up the bolts that hold the door to the top hinge enough to slip the top back a bit to even up the gap at the top even though it will be more than you want.
Then raise the door to get your lines closer together. A jack or a strong and patient helper go a long ways here.
You may end up elongating the holes in the hinge to get more adjustment before you are done.
It's going to be a little bit by little bit process with a bit of hair pulling mixed in for good measure before you are done.
My ongoing truck projects:
Old 05-22-2015, 07:26 PM   #4
crazyjim
crazyjim's Avatar
I have taken the vertical up a far as it will go.Did not replace hinge pocket it's in real good shape,latch is a little low but it works if i line up crack around the door then the latch is to low and hits the striker plate.
Old 05-22-2015, 07:29 PM   #5
crazyjim
crazyjim's Avatar
Thanks for your info i think my best bet is to elonggat the hing holes in the hinge
Old 05-22-2015, 07:35 PM   #6
OrrieG
OrrieG's Avatar
Do not understand how they fit before and now do not. But try opening up the slotted holes per Mr48.
Old 05-22-2015, 08:34 PM   #7
crazyjim
crazyjim's Avatar
When i bought the truck the doors where on it but the striker plates were not i found the striker plate it had a big groove where the latch was hitting it.
Old 05-23-2015, 04:41 PM   #8
48X3600
48X3600's Avatar
How did you rebuild the hinges. If you removes the hinge pin itself are you certain the right halves were put back together.
I assume you have followed the service manual?
http://chevy.oldcarmanualproject.com...51ctsm0106.htm
48 3600 pickup baking in the desert sun.
48X3600 is offline   Reply With Quote
Old 05-23-2015, 10:50 PM   #9
crazyjim
crazyjim's Avatar
[QUOTE=48X3600;7183075]How did you rebuild the hinges. If you removes the hinge pin itself are you certain the right halves were put back together.
http://chevy.oldcarmanualproject.com...51ctsm0106.htm[/QUOTE Yes i put the right halves in the right spot.
Old 05-24-2015, 06:55 AM   #10
msaintg
msaintg's Avatar
I have that exact issue. everything fits perfect except those lines don't match up.... but only on the drivers side. I figure it just came from the factory that way, so I just left it.
msaintg is offline   Reply With Quote
Old 05-24-2015, 11:42 AM   #11
greg_h
good hinge rebuild video. https://www.youtube.com/watch?v=aEoBFw8kaTE
greg_h is offline   Reply With Quote
Old 05-30-2015, 12:52 AM   #12
crazyjim
crazyjim's Avatar
I got it by oblonging the holes in the hing strap thanks guys.
Old 05-30-2015, 01:03 AM   #13
mr48chev
mr48chev's Avatar
Cool.
Old 02-05-2017, 09:02 AM   #14
Jemezcrusher
Mocking up my 50 and have the same issue of belt line not matching up. I have elongated the holes in the rebuilt hinge arms and have really good side gaps. Both doors are as high up as they will go on the pocket adjustment but still could stand to come up 3/16th of an inch.
It really seems that the belt line on the door is a scosh wider than on the cab and looks a little weird if hanging a little low.
I am wondering about opening the holes upward in the hinge straps to give the doors some more upward movement but am wondering if that will have any negative impact on the strength of the grip of the bolt on the hinge arm
Jemezcrusher is offline   Reply With Quote
