Old 05-22-2015, 08:54 AM   #1
chewiebarker
chewiebarker's Avatar
Emission fitting on poly tank?
I just successfully swapped in an MTS poly tank for my 1971 K20 Sub (and ditched the black sludge in the old tank!). The new tank come with two copper 'emission fittings' in addition to the vent pipe. What am I to do with these. As you know, the original tanks don't have such things.
Do people just plug them? If so, what do you use to plug them?
After filling the tank and driving around I noticed it still smells and I assume that is from these open valves.
1971 K20 Suburban
2012 LS1500 4WD Suburban
2003 Honda Accord LX V6 (don't tell anyone)
MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915
chewiebarker is offline   Reply With Quote
Old 05-22-2015, 09:58 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Emission fitting on poly tank?
In '72 you would have two lines, from the tank, going to the fuel separator.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-23-2015, 12:50 AM   #3
rocknss
rocknss's Avatar
On my 69 Burb when I swapped in a Poly tank I just capped the unused fittings using hose and a bolt clamped in the hose. I don't smell gas from the new tank at all.
In your pic showing the new poly tank the barb fitting next to the filler hole is the overflow fitting that should connect to the fuel filler neck. That is how its on my 69, maybe someone will chime in about a 72.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 05-23-2015, 01:24 PM   #4
mdw
I am about ready to put the same tank in my 71, I am just going to cap them off but will use them when I go to f.i. for the return line.
mdw is offline   Reply With Quote
Old 08-19-2015, 11:43 PM   #5
Jbsweezy
Jbsweezy's Avatar
So I am about to do the same thing very soon. Should i just cap off the emission fittings or run them into the canister in the back?
Jbsweezy is offline   Reply With Quote
emission fitting, fuel tank swap
