Old 09-02-2003, 05:31 PM   #1
jay6891
Car Knocker
jay6891's Avatar
700r4 to 400
A freind of mine has had it with the 700r4 in is 93 truck. Wants to go to a 400 turbo. anybody know of a web site that will give me the diminsions of each so we can get his driveshaft redone. He will have to lengthen won't he? Long wheel base truck so how long is to long ( in the driveshaft dept). anybody have any experience in doing this? thanks Jay
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-02-2003, 05:40 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd say the main issue to overcome here is that his truck uses an electronic speedometer signal. You'll need to configure the 400 to do the same. Late model 454SS trucks had turbo 400s with the electronic dash, so that's one road you might check out.
Old 09-02-2003, 05:43 PM   #3
jay6891
Car Knocker
jay6891's Avatar
good point, I didn't think about the speedo. Was thinking of computer controls on engine. Any Idea if it will effect them?
Old 09-02-2003, 05:45 PM   #4
Tx Firefighter
If worse came to worse, you could model it around a manual tranny truck. They didn't use any electronics on the tranny. The engine wiring was stand alone.
Old 09-02-2003, 07:21 PM   #5
68 Suburban
68 Suburban's Avatar
You should check into a 4l80e trans, which is a turbo 400 with overdrive. They were put in the heavier duty trucks instead of the 4l60e (700r4) trans. I think that would be your best bet.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 09-02-2003, 08:10 PM   #6
jay6891
Car Knocker
jay6891's Avatar
Yea I here ya on keeping the overdrive. I tried to talk him out of it but he is low on funds and he can get the 400 turbo for 400 and fresh rebuild. He's a single parent and this is the third 700r4 he had. this last one is only about 6 months old and the dude that rebuilt has skipped town.
