Old 05-23-2015, 03:45 PM   #1
aod92
aod92's Avatar
Steering column help????
I took this apart a while ago and now I'm trying to figure out how to put it back together. How does the top piece with the hazard button attach to the bottom? Does it twist together with the tabs? Your help is appreciated.
aod92 is offline   Reply With Quote
Old 05-23-2015, 05:59 PM   #2
70shortfleet
70shortfleet's Avatar
Re: Steering column help????
The piece you are holding in your hand will slide over the end of the main shaft after you line up the tabs that are sticking out on the end of the shaft with the half moon shaped indentions on the piece you are holding and I think turn little to the left and tighten turn signal screws down. Hope I expaid it well enough
70shortfleet is offline   Reply With Quote
Old 05-27-2015, 09:32 PM   #3
aod92
aod92's Avatar
Ok I'm still really confused on this one. How far do you turn it so you know it's clocked right? Also are this rubber washer and plastic washer in the right order?
