front 5 lug disc swap parts list
I have a 68 c10. need a complete junk yard parts list for a disc swap for 5 lugs from 6.. I plan on using drop spindles so what year drop spindles should I use as well? I cant find clear information on this so thanks in advance
Re: front 5 lug disc swap parts list
Here's the complete list of what you need to do the swap http://67-72chevytrucks.com/vboard/s...d.php?t=456889
1969 Chevy C10 Short Step -Project 2005 GMC Sierra Crew Cab 1500 -DD 2017 Laguna Orange Roadglide - Good Weather DD |
67-72 parts collector,…
![]() Join Date: Nov 2002
LIST:
63-70 conversion drop spindles. $229 everywhere. 71-87 HD 1.25" rotors 71-87 HD calipers 71-87 HD bearings I would use nothing from the junk yard except the dust shields. Buy ECE conversion brake hoses. ECE also sells dust shields. Your drum spindle nut will work on the new drop spindles. 71-72 M/C 71-72 Prop valve or aftermarket equivalent. Not the answer you want. But EVERYTHING in the junk yard is wore out!
actually keith that is exactly what I needed. thanks!!
