05-23-2015, 09:49 PM | #1 |
Motor
Who makes the best motor? I was thinking of putting a new 350 in my truck to replace the 305 engine. I know there is a big range of prices. I will probable go for the middle of the road in price? Thanks, Al
05-23-2015, 10:00 PM | #2 |
Re: Motor
Pull a 350 from a junk yard and build it up with a cam, set of heads, headers and so on. Best motor made is your own
05-23-2015, 10:16 PM | #3 |
Re: Motor
Personally, I don't 100% trust any engine I didn't build myself.
If you have the tools and knowledge to build one, I would recommend that way. If you are going to spend money and buy one, it's a roll of the dice no matter where you get one. Even the best engine builders occasionally have a bad day or piece of equipment not working properly.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
05-23-2015, 10:32 PM | #4 |
Re: Motor
I understand, but I don't think I could trust an engine I built. Ha Al
05-24-2015, 09:44 AM | #5 | |
Re: Motor
do you want a complete ready to drop in engine? or just the long block so you can hang all your parts on it? need a little more info
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
05-24-2015, 10:49 AM | #6 |
Re: Motor
If I didn't have engine building skills, I would buy a crate motor from GM.
05-24-2015, 11:03 AM | #7 |
Re: Motor
I will be replacing the tired 305 in my truck with a crate from GM. Stuck between the $1500 Goodwrench 350 or $3000 350HO. $1500 can buy me a lot....
1982 K10 SWB 1987 V20 - Sold - Doh! |
05-24-2015, 01:12 PM | #8 | |
Re: Motor
And even the base 350 Goodwrench engine for approx $1500 will make you grin compared to a worn out 305.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
05-24-2015, 01:31 PM | #9 |
Re: Motor
It would be a daily driver, probably not more than 3000.00. Thanks, Al
05-24-2015, 01:32 PM | #10 |
Re: Motor
Drop in for me, small block is fine. Al
05-24-2015, 03:15 PM | #11 |
Re: Motor
That's a great price. You would be hard pressed to build one for that kind of money and have a warranty (I assume there is a warranty).
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
05-24-2015, 05:20 PM | #12 |
Re: Motor
talk to Matt over at engine factory dot com
05-24-2015, 05:33 PM | #13 |
Re: Motor
If you were closer I'd sell you mine. I built a zz430 clone with a th350 TCI street fighter kit and 2800 nitrous stall
