Old 05-23-2015, 10:29 PM   #1
stepsider
stepsider's Avatar
Question My Transmission
I have a TH350 (13 bolt Pan), While doing my rewire in the engine bay, I pulled a electrical plug from the trans. Don't know what year the trans is. Could this be converter lockout ? Did they come in 1971 GMC ? If so how do you wire it. What happens if its not hooked up ? Looking for info. Thanks
stepsider is offline   Reply With Quote
Old 05-23-2015, 11:55 PM   #2
fat dan
Keep on Trucking
Re: My Transmission
It's the torque converter clutch, if you don't use it you will lose the converter lock up function which will cause reduced gas mileage.
fat dan is offline   Reply With Quote
Old 05-24-2015, 12:22 AM   #3
truckster
truckster's Avatar
Re: My Transmission
Torque convertor lockup on a 71? No, they didn't have locking torque convertors. None of the THM 350s did.
truckster is offline   Reply With Quote
Old 05-24-2015, 12:24 AM   #4
fat dan
Keep on Trucking
Re: My Transmission
In order to wire it up you will need a kit from B&M. Summit has tem for $190.
Old 05-24-2015, 12:27 AM   #5
fat dan
Keep on Trucking
Re: My Transmission
You have a 350C transmission.
Old 05-24-2015, 01:20 AM   #6
SS Tim
SS Tim's Avatar
Re: My Transmission
Sounds like the plug for transmission controlled spark used as part of CEC system in 71. That would be the only wiring on a factory 71 TH350 installation. Might try the service manual ection 6T (71 and 72) for some more information, I just don't have the time now.
If you can post a picture I might be able to confirm it later for you.
* VIN/Model Decoders
* Power Team Charts (engine/transmission/gear ratio)
* Post Your Pickup SPID Blazer SPID Suburban/Panel SPID
* RTFM
... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 05-24-2015, 09:32 AM   #7
stepsider
stepsider's Avatar
Re: My Transmission
Thank you SS Tim, I think you hit the nail on the head. The picture shows the spot where the wire plugs in.
