Old 05-24-2015, 12:00 AM   #1
aviatorskate
Upper Control arm install.
Does this look correct? Hardware set up? Shaft is centered on control arm.
1970 C10
Craig
aviatorskate is offline   Reply With Quote
Old 05-24-2015, 01:03 AM   #2
BigMike
BigMike's Avatar
Re: Upper Control arm install.
Looks normal to me except a little pulled away, don't think it will affect anything. Here's mine, just finished installing all new joints and bushings and shafts. Just got it re-aligned today. Do you have the upper arm rubber stopper? I had to put a temporary one on mine because I couldn't find the upper or lower one when I put it together. Later I found that LMC has them so I ordered them and will install them later. My truck is slammed so I don't think it will be an issue, only when I jack it up.
BigMike is offline   Reply With Quote
Old 05-24-2015, 11:24 AM   #3
dfosh
I think the bolts for your ball joint should come up from underneath . Nuts for bolts on top .
dfosh is offline   Reply With Quote
Old 05-24-2015, 12:28 PM   #4
aviatorskate
I haven't bought new rubber stoppers yet. I bought some stuff from lmc which included new shafts, shims and another piece that goes between the shims and the cross shaft. Did not know if it was right. Took it a part 15 years ago and don't remember.
Old 05-24-2015, 01:42 PM   #5
davepl
davepl's Avatar
Hard to tell from the first photo which way we're looking, at least for me.
The rubber bump stop goes towards the rear of the vehicle. And yes you can install them (or at least one of the upper or lower arms) on the wrong side.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-24-2015, 03:39 PM   #6
BigMike
BigMike's Avatar
Yes, his uppers are correct. The snubber platform should face towards the rear and the lowers will have the bottom shock mount also facing the rear. When I did my upper & lower shafts I marked the nuts with my dremel and counted each turn to make sure they were as close to even as possible. If you put some grease on the insides of the arm, where the nuts go into, it makes it MUCH easier to tighten. When you get it aligned they will +/- shims as needed.
Also, it looks like your lower arm is installed already? Looks like you can barely make out the bottom shock mount. If it is then it's on the correct way.
Here is a great link that Sharps40 did that I followed when I put my stuff back together.
http://67-72chevytrucks.com/vboard/s...d.php?t=556867
Good luck
Old 05-24-2015, 04:00 PM   #7
aviatorskate
Do the nuts need to be on top of the ball joint or does it matter ?
Old 05-24-2015, 04:05 PM   #8
FirstOwner69
FirstOwner69's Avatar
My Moog instructions said the nuts go on top. I read someplace this is to reduce the chance of rupturing a boot with the end of a bolt.
By the way.... Welcome to the forum!!!
FirstOwner69 is offline   Reply With Quote
Old 05-24-2015, 04:07 PM   #9
aviatorskate
Thanks to all.
Craig
Old 05-24-2015, 04:25 PM   #10
aviatorskate
I don't think the cross shaft is all the way tight. The nuts are snug but I can still rock the a arm from side to side.
Old 05-24-2015, 05:02 PM   #11
BigMike
BigMike's Avatar
Ya, that shouldn't happen. If it were me I would redo it. I had to redo one of mine, I wasn't quite sure it was correct so I re-did it just to be safe. Both of my uppers & lowers were pretty snug and had no movement in them. I did tighten mine beyond snug though, they were torqued down pretty tight.
Good catch FirstOwner69, didn't see that. Yes, the nuts should be on the top to prevent damage to the boot.
Old 05-24-2015, 06:17 PM   #12
chiefcfd
chiefcfd's Avatar
It looks like the washers and shims are reversed. The washer goes toward the frame and the shims between there and cross shaft. Big Mike has it right. The pic in post #6 is right.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 05-24-2015, 09:27 PM   #13
aviatorskate
I will move the shims. I finally got it tight. I used the original cross shaft and removed the lmc Taiwan made one, works good.
